Results 21 to 33 of 33
Thread: Oversized compressor
  1. #21
    Mar 2021
    Quote Originally Posted by R600a View Post
    I put an under sized compressor in my ac and it works surprisingly well. I don't think oversized would work quite as well.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    That’s what I ended up doing and worked fine!
    Quick reply to this message Reply
  2. #22
    Jan 2014
    New England/Florida
    Increased SEER and EER rating also
  3. #23
    Jan 2014
    New England/Florida
    Quote Originally Posted by Bruce.nrz View Post
    Increased SEER and EER rating also…
  4. Likes Bruce.nrz liked this post.
  5. #24
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Quote Originally Posted by Bazooka Joe View Post
    Mine just almost accounted for the damage to the condenser coil so I think I didn't gain any efficiency I just lost capacity. Before this craziness with the copper prices I was planning on changing the system out but now I'm thinking I waited a bit too long.
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  6. Likes Bruce.nrz liked this post.
  7. #25
    Oct 2018
    saudi arabia
    How much oversized?
    It can be fine, but you need to observe the system reading and some extra refrigerant is needed.
    Power consumption will be increased, also delivered capacity will increase.
    I would recommend ask for compressor performance sheet and it will show you all changes.
    But donÂ’t go far in over sizing. Also as folks mentioned check if this violating any code.
  8. Likes Bruce.nrz liked this post.
  9. #26
    Oct 2018
    saudi arabia
    Quote Originally Posted by mohad_i View Post
    How much oversized?
    dont forget to check the electrical components if still fit or need to oversize also.
    the oversized compressor will consume more power and ampere.. make sure the installed wires/breakers/contactors/overload/... can handle the new ampere?
  10. Likes Bruce.nrz liked this post.
  11. #27
    Mar 2021
    That’s true, we ended up to downsize the compressor tho, thanks anyway
  12. #28
    Apr 2021
    What is the feedback after the change in compressor?
  13. Likes Bruce.nrz liked this post.
  14. #29
    Mar 2021
    Quote Originally Posted by Pietro8 View Post
    We’ve put an smaller compressor on a custom designed heating and cooling unit in a condo and surprisingly it’s working just fine. There’s a shortage of parts and we’ll replace all those old units shortly, anyway.
  15. Likes R600a liked this post.
  16. #30
    Chicago area
    I can speak 1st hand that unless the metering device and air volume will support the compressor capacity, it will run much lower then desired evap saturation.
    Have a hard time starting without equalized pressure, and likely to freeze up.
    Had a condo with a 2 ton unico type indoor that another guy installed a 3 ton condenser on.
    Hard to keep above 15 degree saturation.
    The fix was a compressor that matched the indoor unit.
  17. Likes R600a, Bruce.nrz liked this post.
  18. #31
    Mar 2021
    Quote Originally Posted by heatingman View Post
    This is two size bigger! It will be no superheat, regardless we match the measuring device with outdoor unit or not, that’s a mess for sure, thanks for sharing anyway.
  19. #32
    Aug 2021
    Chattahoochee State Mental Hospital
    Let's not forget about humidity issues. It has to run long enough to maintain humidity control. 80 degrees @ 45-50 relative humidity feels much better than 73 degrees@80%rh...
    .Please consider donating $11 to Tunnels to Towers, a great way to help Veterans, who fought communist ideology all over the world.
    Hail the Republic!
  20. Likes R600a, Bruce.nrz liked this post.
  21. #33
    Chicago area
    It had a TXV and did maintain SH, just the evaporations pressure was too low to keep anything above freezing
  22. Likes Bruce.nrz liked this post.
Quick Reply Quick Reply
Register Now
Log-in
