+ Reply to Thread
Results 21 to 40 of 56
Thread: Best install yet
  1. #21
    Jan 2010
    You can bring your your suction straight down then use one long sweep street 90 into the evaporator no bending required.
  2. #22
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Normally I just bend a 90 straight into the evaporator but I thought I needed a trap.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  3. #23
    Jan 2010
    Oh I see now what you were doing.
    So in refrigeration we buy pre made traps for the bottom of a riser.
  4. Likes Zamoramax, R600a liked this post.
  5. #24
    R600a's Avatar
    Jul 2019
    So in refrigeration we buy per made traps for the bottom of a riser.
    Exactly. I just only had soft copper and the store was closed.
    My trap has much less volume than those premade ones.
  6. #25
    Jan 2010
    Sometimes you gotta do what ya gotta do 👍🏻
  7. Likes R600a liked this post.
  8. #26
    May 2014
    Bay Area California
    If you have a split system 5 tons or less, can someone explain to me why traps are necessary?
    No one ever cared about them before, and those systems lasted forever.
    I do a triple evac with nitro to remove non condensables.
  9. Likes jacob-k liked this post.
  10. #27
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by BBeerme View Post
    They probably are not important.
  11. #28
    Feb 2013
    Sonora, California, United States
    Ive still never installed one or seen one in residential around here.
  12. #29
    Jan 2010
    I'm still scratching my head on this ....
    It must be late and I need some sleep.
    How is a vapor line in heat mode a riser ?
    They must be talking about cooling mode.
  13. Likes R600a liked this post.
  14. #30
    R600a's Avatar
    Jul 2019
    The suction velocity is between 1200 and 1500 fpm which should be plenty to the blow the oil along according to the manuals.
  15. #31
    Where is air filter?
    FYI-it will be to your advantage to ensure there is a few extra inches to any wire termination.
  16. #32
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by dandyme View Post
    The air filters are in sealing return grills
    I try to hide extra wire out of sight.
  17. #33
    Apr 2020
    va
    Quote Originally Posted by jacob-k View Post
    If you used compressors like the Tecum... sf, discharge cooled motors, even the slightest floodback or flooded start would kill em. Anytime the evap was high an inverted trap to the coil height was recommended.
  18. #34
    Sep 2020
    Maryland
    Looks great !
    I have 4 installs under my belt but my last one still does not look as neat as yours.
    And your 0.32inWC static is amazing. So far I've never seen anything near 0.5, mostly 0.6 to 0.8.
    I think you made a typo on the Blower Amp of 0.3. I guess that would be a 1/2HP Motor which should draw around 3A.
  19. #35
    Sep 2020
    Maryland
    Your braze joints look great, especially being so close to the cabinet.
    I'm trying to improve mine as well, with the help with a Captain Hook.
  20. #36
    State College, PA
    But I think a lot of those old systems had undersized vapor lines which increased velocity.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
  21. Likes R600a liked this post.
  22. #37
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by UltraCool View Post
    Looks great !
    The static was really just luck of the draw. That's for the amperage I wrote down what I thought I saw but who knows. The screen in watt mode on my supco redfish idvm550 has so many things displayed that they're all really small and hard to see.
  23. #38
    R600a's Avatar
    Jul 2019
    This was a number two single tip on my Victor torch and about 5 years of practice. My first one looked like I'd spray textured the joint with braze and it never really improved until I figured out that I needed to run more fuel and less oxygen.
  24. #39
    Mar 2013
    Treasure coast, FL
    It says "when flow is reversed" as in cooling mode.
    Sent from my motorola one 5G UW using Tapatalk
  25. Likes R600a liked this post.
  26. #40
    May 2021
    Great job!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
