+ Reply to Thread
Results 1 to 7 of 7
Thread: Hose binding question?
    Mar 2021
    St Louis
    Good afternoon everyone,
    This may be a silly question, but due to how this and several other warehouses that we maintain are set up, we have to run our hoses from the ground and across the roof.
    Does anyone know of something that can help keep the hose from pinching off as it crests the edge of the roof?
    Water pressure is limited as you venture further away…
    Thanks in advance for any ideas.
    TravisName:  IMG_3308.jpg
    Mar 2021
    St Louis
    I do have some slack added in an attempt to lower the chances… what good that may do.Name:  IMG_3307.jpg
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    I use silver bullet expandable hoses and they do not kink. The only problem with them is they are black and they're not very heat resistant so in the summer you can never turn the water flow off or they will overheat and blow out.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
    New Jersey
    Attach a rope below the roof parapet to take some weight off the hose. For more water pressure, put a booster pump on the hose. If your are doing a lot of roof work a booster pump really helps getting coils cleaned out properly.
    Sent from my ASUS_P00J using Tapatalk
    Mar 2018
    Virginia
    Try and prevent it from making a sharp turn. You can fold up a drop cloth or a sweat shirt or something and put that on the edge so the hose is making a more rounded turn and less of a 90 degree turn.
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
    Nov 2011
    CO
    Or get some heavy duty hose that won't kink. Just had to buy a 100' roll yesterday for a roof. Closest choice was ACE hardware. They had a craftsman 6 sided (not round) heavy duty that didn't kink at all going over the parapit wall.
  7. Likes R600a liked this post.
  8. #7
    Mar 2021
    St Louis
    Thanks all for the ideas. I’ll certainly put them to use.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
