+ Reply to Thread
Results 1 to 20 of 20
Thread: VACUUM Pump Repair
    May 2021
    Hmm VACUUM Pump Repair
    My Pump took a dump so here I sit full of pit.
    I took the cover off my Bacoeng 3 cfm Rotary Vane Pump and found a broken flat metal shim that is fastened by a screw to the top of the cylinder housing and it covers a discharge port for oil to circulate through the cylinder.
    I think its aluminum metal so I cut my own from what I could find the hardware store , small peice about 3/4" x 1/2". Seems to work better But I can only pull down to 230 mics for a blank off test.
    I cant get the Bacoeng manufacturer to respond quickly to my picture request.
    Does any one know the technical name for this metal shim cover?
    And, is it ok to use any aluminum to make my own untill I can find the proper replacement?
    Mar 2018
    Virginia
    Can you post a picture?
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
    May 2021
    Quote Originally Posted by JayMan7 View Post
    I dont seem to be able to, I read the directions on how to post using the attachment icon, I dont see an attachment icon, so I think I havent posted enough threads yet " Forum Rules".
    May 2021
    Found the icon
    Mar 2018
    Virginia
    So is that like a reed valve? Can you post a pic of where it goes on the pump?
  6. Likes R600a liked this post.
  7. #6
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    It looks like a valve and maybe the manufacturer didn't put a stop so when you first pull down from atmospheric the valve gets over stressed.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  8. #7
    May 2021
    Here you can see the stop and my replacement but my replacement started getting an upward curve that doesnt let it seat flush after you run it for awhile.
  9. #8
    Mar 2018
    Virginia
    Quote Originally Posted by AC Hacker View Post
    Just a thought...try using a feeler gauge to make that...they’re kinda springy and seem really tough. You could try different thicknesses until you get one that works.
  10. Likes R600a liked this post.
  11. #9
    R600a's Avatar
    Jul 2019
    Save up for a jb industries 5 cfm.
    It'll cost you more than four times but that one cost but they're built right to begin with.
  12. #10
    May 2021
    OK, that worked out great, I was able to match the manufacturers thickness of the reed valve and can pull 75 mics with rig and core remover attached. Thanks guys for all your help.
  13. Likes R600a, JayMan7, ksefan liked this post.
  14. #11
    R600a's Avatar
    Jul 2019
    This was from my vacuum and decay test today with my 1987 (or something like that. I don't remember for sure.) JB industries 5 cfm vacuum pump.
  15. #12
    R600a's Avatar
    Jul 2019
    Don't mind the white lineset. This was for a friend and I warned him about Chinese line sets so if it goes bad I am charging full price to replace them.
  16. Likes JayMan7 liked this post.
  17. #13
    Mar 2018
    Virginia
    Nice dude! Glad it worked for you!
  18. Likes R600a liked this post.
  19. #14
    Mar 2018
    Virginia
    Quote Originally Posted by R600a View Post
    Yeah those bluvacs really are sweet! You got one heck of a good vacuum on that system!
  20. #15
    Mar 2018
    Virginia
    VACUUM Pump Repair
    Oh you got those big blue hoses too I didn’t notice that at first. That’s a pretty nice set up.
  21. Likes R600a liked this post.
  22. #16
    R600a's Avatar
    Jul 2019
    Yep. As they say go big or go home.
  23. Likes JayMan7 liked this post.
  24. #17
    May 2021
    Always the forum rules limit access, to important objectives important to the company. In the final analysis, it would be prudent and of great convenience to the board if they actually become more aware of what they're writing for the terms and conditions. In all honesty, it seems that they're completely oblivious in what they write. It would also be prudent if the rules simply followed a thorough standard of logic and common sense. Of course the board has their opinion on it following the laws of logic and common sense or in some cases defy these laws altogether.
  25. #18
    May 2021
    Outstanding, this board is going by the measurement of the Metric System. Let's make charts like these more frequent.
  26. #19
    May 2021
    Which is equivalent to the phrase all or nothing.
  27. #20
    May 2021
    I completely agree.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
