Results 1 to 9 of 9
Thread: INSTALLED CORRECTLY?
    May 2021
    Exclamation INSTALLED CORRECTLY?
    A recent Home Inspection revealed a problem with the installation of my HVAC in the attic. The installer insists it is correct; however, two other dealer/installers disagree. Dear Professionals, Do I have a problem here, and can you describe what (or if) is the issue?
    wrt pics: the air enters from the right side of picture, travels through the coils, then the furnace, and out the ducting to the left of picture.
    Thank you!
    (I've seen several threads that seem to address the issue and I'd appreciate any links to avoid repeats if that's easier...thank you!)\
    Jun 2014
    Dover, DE
    Evaporator should be on the outlet of the furnace. Your quickly killing (or have already killed) your heat exchanger. Hence the rust you see in the burner area.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
  3. Likes R600a, Bearcat73 liked this post.
  4. #3
    Houston,Texas
    Burning refrigerant in an open flame can create Phosgene gas, so if your evaporator was to start leaking refrigerant, it would go right into your heat exchanger.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
  5. #4
    No it wouldn't. It would be in the normal air stream, and would never get hot enough to create phosgene gas.
  6. #5
    Have the installer that says the install is correct, show you the install manual that says that.
    It will greatly shorten the life of the furnace heat exchanger. By causing condensate to form inside the heat exchanger, and rot it from the inside out.
  7. Likes Bearcat73, kdean1 liked this post.
  8. #6
    Southold, NY
    Quote Originally Posted by Bearcat73 View Post
    Thank you!
    Now that luck.........You managed to find a Home inspector that actually knows what he looking at!
  9. Likes Bearcat73 liked this post.
  10. #7
    May 2021
    Quote Originally Posted by rider77 View Post
    That's what the other installers stated.
    So this is not due to "rain water" coming down the flue (that's what the installer told me...that it had nothing to do with the HX downstream the evaporator....)
  11. #8
    Houston,Texas
    Yeah I forgot, it’s was late, all your gas packs are like this anyway.
  12. #9
    May 2021
    Well, truth be told, the Home Inspector actually saw the rust, which prompted the calls to HVAC professionals that immediately saw the problem. I just wanted to make sure that other installers agreed that the "horse should proceed the cart," that a "truck should pull a boat, not push," that installation manuals should still be referenced.
    I greatly appreciate the expertise on this forum. Thank you.
  13. Likes Mr Bill, beenthere liked this post.
Tags for this Thread
