Results 1 to 10 of 10
Thread: JCI NAE Firmware Compatibility
    Mar 2012
    North Carolina
    Is there a document or can someone enlighten me on the compatibility of NAE Metasys revisions with the actual hardware part numbers.
    For example, a NAE5510-1 can be Nutted to what Revision of Metasys.
    And you can backup what version of Metasys with which version of SCT?
    For example, with SCT 12.0 it looks like you can backup a NAE with Metasys 5.2 but not 5.1.
    I would think that JCI has some kind of master spreadsheet that would answer this question but Im sure its impossible to find on the Portal
    Mar 2012
    North Carolina
    Bump
    Apr 2012
    May 2016
    Upstate NY
    file not found
    Kenilworth NJ
    Maybe this does it?
    https://docs.johnsoncontrols.com/bas...tion-Tool-Help
    Says Lit 12011964 on it. Like the PDF number in the URL
    Hmmmm....smells like numbatwo to me.
    Apr 2020
    from off the top of my head
    NAE 35's and NAE45's can only be flashed up to Metasys 9.1.
    NAE55's are compatible with metasys 11
    Mar 2012
    North Carolina
    Im more worried about the old stuff. Ive read somewhere that you cant flash a NAE5510-0 past Metasys 4 because it doesnt have enough memory. I guess you can flash a NAE5510-3 to anything...? What about the -1s and -2s. I am also assuming youve got to have different versions of SCT to back up those NAEs. I have SCT12 and I kept getting a version mismatch error when trying to back up a NAE5510-2 that was at 5.1. I used SCT 5.2 I think and was able to back it up. I tried to use that same 5.2 version to back up a NAE5510-0 that was at 3 something and got the same error.
    Apr 2012
    Metasys 8.0---SCT11.0,
    Metasys 8.1----SCT11.1,
    Metasys 9.0--SCT12.0,
    Metasys 10.0---SCT 13.0,
    Metasys10.1----SCT 13.2。
  9. Likes hvacpilot liked this post.
  10. #9
    Sep 2013
    https://cgproducts.johnsoncontrols.c...F/12011832.pdf
    Page 25. Plus all the way in the back is a list of related literature.
    It is true a NAE55-0 can only got 4.0. Im not sure where a NA55-1 can goto but I think it is 9.06?
    Sent from my iPad using Tapatalk
  11. #10
    NxE 2xxx-x, NxE 3xxx-x, and NxE 4xxx-x cannot be upgraded to Release 10 due to lack of memory. I believe the last version is 9.06
    Metasys release 11.0 is the last supported major release of the NAE55xx-2. NAE55xx-2 cannot be upgraded to Metasys release 12 or later, again due to limited memory.
    NAE55xx-0 and -1 are now boat anchors
    The other thing to keep in mind - if you have older N2 technology and you still want to use passthrou using the site director, the network engine CANNOT go above version 10.1. This is due to FIPS 140-2 Security starting at Metasys version 11.
