Results 1 to 11 of 11
Thread: Refrigerant detectors, which is the best and most sensitive?
    Oct 2012
    South East Pennsylvania
    I would like to get feedback from other field experts, which refrigerant detector works best on r-22, and r410? Does one detector work better on either? Will they detect a formicary corrosion leak? Trying to speed up the dye test method and find leaks faster. Thanks for the help
    Southold, NY
    Quote Originally Posted by treysdad View Post
    Speed up the dye test?
    after a few hours of run time the dye has circulated!
    Oct 2012
    I do not want to sit in front of a system and run for a few hours. I was looking for a method to test immediately and find the leak. By "speeding up" the dye test, I was looking to eliminate the wait. Find leaks now. Hence why I'm asking about the best sniffers.
    Southold, NY
    1st
    Visual Look for oil
    2nd Electronic, model is up to the user and there experience.
    2.5 Soap bubbles
    3rd Dye
    Oct 2012
    I am not asking as a beginner. I am looking for the best sniffer. Anything else is not helpful.If you have used one, and had amazing success, please let me know. If not, I am looking for others who have. I am a field expert / owner who is trying to find ways to help my team collapse time.
    Southold, NY
    I said it its up to the individual tech what there comfy with.
    Ive missed leaks with my H10 that the D-Tech found and visa versa.
    Who makes the best meter, gauges, scale?
    Jan 2010
    If you're not a "beginners" why haven't you already purchased a leak detector at this point ?
    I've never used dye never will.
    Jul 2019
    Oklahoma home its in the name
    The H10 seems to be the most universally respected detector.
    Sent from the Okie state usin Tapatalk
  9. Likes Mr Bill liked this post.
  10. #9
    May 2014
    Bay Area California
    Yeah, I'm an H-10 fan myself. That being said, all you can get anymore is the H10 pro, which takes a certain amount of experience and practice to use properly. It will detect 1/2 of 1 oz per year leak. That means it would take 32 years to leak out one pound, that's how sensitive it is.
    I do a triple evac with nitro to remove non condensables.
  11. Likes Mr Bill liked this post.
  12. #10
    Cincinnati, Oh
    Quote Originally Posted by BBeerme View Post
    Biggest issue with the h10, is one I had today.
    Desert air. Reheat and evap are 1ft from each other. Took me forever to dial in, due to have high the sensitivity can be.
  13. #11
    May 2014
    Bay Area California
    You can de-tune it. You've got the small-med-large switch, then you got the knob. Had one a couple of weeks ago. Two other co-workers had looked at it before me. Had to put the switch on large then keep turning the knob to less and less sensitivity. Once I got pretty close, squirted bubbles all over, and I'm the hero of the day.
    Quote Originally Posted by hvacvegas View Post
