Results 1 to 20 of 27
Thread: Heat Pump Operations Question...How low can you go?
    Jan 2021
    I've been wondering...how much 410a can leak out of a heat pump system before a homeowner would notice that it is not heating or cooling correctly? Can heat pumps work with a certain level of reduced charge? (I'm asking because I suspect I've had a slow leak from one of the Schrader valves because I was finding oil on the plastic cap, and have since replaced it with a nice brass cap)
    Thanks!
    Southold, NY
    How much air can you loose out of a tire before it wears differently?
    Jan 2021
    You can run a tire 1-2 psi above or below the recommended setting and not notice much difference. You can run a car 1/2 qt low on oil and it will run fine. So what about a heat pump? At what level of loss of 410a will the system stop working or will a homeowner notice a significant loss of heating/cooling?
    Jan 2010
    Well once you have no sub-cooling it's down hill fast from there.
  5. Likes R600a, jacob-k liked this post.
  6. #5
    Jun 2014
    Dover, DE
    Your asking a generic question about your unit that has no generic answer.
    It would be determined by your specific system and setup.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
  7. #6
    Jan 2014
    New England
    Great to hear..thanks. I'll check it with soap and just keep an eye on it.
    https://hvac-talk.com/vbb/threads/22...ighlight=Scguy
    Above is from your last post, from earlier this year, when they replaced the indoor coil. Did you find it leaking then? Did you replace the cap then or recently?
  8. #7
    Southold, NY
    Quote Originally Posted by SCguy View Post
    NOT notice much deference!
    1/2 qt low really, why do they say X amount of oil and not Just Under this much?
  9. #8
    Jan 2021
    Bazooka Joe:
    Never saw bubbles but what I noticed was after running the AC (infrequently since not too hot yet) there would be a small amount of oil on the outside of the plastic cap. Just enough to feel between your fingers. So just yesterday I replaced the plastic caps with a brass ones thinking if the valve has a small leak that a brass cap would stop it.
  10. #9
    Jan 2010
    If the core in your Schrader valve is leaking it should be replaced.
  11. Likes dan sw fl liked this post.
  12. #10
    Jan 2021
    Yes, that's my next step... call a pro out to replace it.
  13. #11
    Jan 2014
    New England
    I suppose check with soap ( system off ) here and there, later in warmer weather and run in cool, your looking for 18-20 give or take degree temperatures difference using a accurate thermometer ( not IR Gun ) and let system run 15 minutes to stabilize before checking. Put the thermometer in a register closest to the Air Handler, same with the return. Having a good load on the inside of the residence also, say 75+ degree.
    They make two types of brass caps, circular with a neoprene O ring, which is finger tightened firmly or the Hexagon type ( no neoprene O ring ) that needs to be tightened with a adjustable wrench.
  14. #12
    Jan 2010
    It's a very simple procedure and I'd be surprised if a service provider would charge more than a service call.
    Well, maybe a small fee for the core.
  15. Likes R600a liked this post.
  16. #13
    Jul 2019
    Oklahoma home its in the name
    One thing about heat pumps is they are often configured for comfort over efficiency and the backup heat kicks in so quickly that no one notices when it has totally run out of refrigerant. That said I am sure you would notice if your heat pump was not running anymore.
    Sent from the Okie state usin Tapatalk
  17. #14
    Jan 2010
    That is true until they get their next electric bill 😳
  18. Likes R600a, BALloyd, BBeerme liked this post.
  19. #15
    Jan 2021
    Yes, once our usual hot and humid SC summer kicks in, I'll take those measurements. The brass cap I have is circular with a neoprene O ring but as suggested above will likely have the valve replaced too. Thanks!
  20. #16
    Jan 2021
    UPDATE:
    So the heat is on here in S.C! The difference between the intake and output at the register was only 13-14 degrees, and it took much longer than expected to cool the house at night (1 hr to lower temp one degree). So called for service.
    Told them the story of the oil around the Schrader valve. His electronic sniffer could not confirm a leak at the valve but he stated the valve "was loose" so he carefully tightened them. He said the sub-cooling was off and that I was down 2 lbs of 410a, so he added it. Now temp difference between intake and output registers is 18.
    Hope it's NOT the coil in the air handler that was replaced this past winter that's leaking! Fingers crossed.
  21. #17
    Jan 2014
    New England
    Sounds like you got shoe maker service company, or a inexperienced service Tech. last time, was the valve cover cap loose or the valve stem loose. To me it’s on them for not tightening the caps when they left last time..
    What does the invoice say, ...please tell me they gave you a legible somewhat detailed invoice....
    Weren’t you talking about replacing this system sooner than later in your other threads?
    If so IMO, get a uncomplicated less bells and whistles system.....
  22. #18
    Southold, NY
    B S
  23. Likes Bazooka Joe liked this post.
  24. #19
    Jan 2021
    No, after the coil was replaced, I notice recurrent oil around on one the plastic caps that was on tight. I since replaced it with a brass cap and no more oil was seen.
    But, could tell the AC was not cooling as well as it should which made me call for the service call.
    He could not confirm a leak from the Schrader but he "tightened" the Schrader valve based on what I had seen with the recurrent oil (not the cap but "tightened" the inside piece which I guess is the valve stem?), and add the 410a.
    No plans to replace system but if we do would not get a bells and whistle system.
    They Email invoices 10 days after service, so don't have it yet.
    So the question is, can the inside of a Schrader valve (the stem) be "loose" as the tech suggested and cause 410a loss?
  25. #20
    May 2014
    Bay Area California
    For what it is worth, my electronic leak detector is so sensitive, I can remove the shrader cap and pick up a leak on every shrader. What's fun is to show a rookie how much refrigerant vapor is still in the cap after you remove it.
    If your tech could not pick up a leak, he has a very inexpensive leak detector. If he did not replace the shrader valve, it's likely he doesn't even know there is a tool out there so you do not lose any refrigerant. Or, if he knows about it, he is not professional enough to go out and buy it. Or, he isn't getting paid enough to buy the proper tools. Or . . . It could go on and on . . . Maybe a judge took all he owns and had it sold at the Flea Market to pay back child support . . . LOL . . . Or . . . Or . . .
    I do a triple evac with nitro to remove non condensables.
  26. Likes R600a liked this post.
