Results 1 to 14 of 14
Thread: Goodman Coil TXV Flare Connection Schrader Vale
    May 2011
    Question Goodman Coil TXV Flare Connection Schrader Vale
    I typically remove the schrader valve on Goodman coils, inside the case at the factory 1/4" flare connection, before I attach the TXV flare nut. I understand this may not be necessary, since the Goodman TXV flare nut has a depressor that opens the schrader valve. This is apparently where Goodman charges the coil with Nitrogen for pressure testing. (Hence the schrader valve?)
    Do others remove the schrader valve, on the coil, before installing the TXV flare nut or am I the only one?
    Jul 2019
    Oklahoma home its in the name
    Weird I thought I saw this topic yesterday.
    I do the same thing.
    I've heard of someone having issues on a York where the depressor didn't work or there was not a depressor or something like that so after hearing that I always remove it.
    Sent from the Okie state usin Tapatalk
    Jul 2019
    AOP is a strange place for this thread.
  4. Likes JayMan7 liked this post.
  5. #4
    Southold, NY
    Quote Originally Posted by Doc Doug View Post
    What does the IOM Say to do?
  6. #5
    Mar 2018
    Virginia
    Quote Originally Posted by R600a View Post
    Yep itís strange along with the other thread lol
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  7. Likes R600a liked this post.
  8. #6
    Mar 2018
    Virginia
    I donít think that there is a dogmatic answer to this but what would be the reason to leave it?
  9. Likes R600a liked this post.
  10. #7
    May 2011
    Fair question. It is not addressed, This is why I presented it for others to comment on.
  11. #8
    May 2011
    Half full or half empty? Good question. Why remove it if you don't have to? It appears that no one has routine experience with this schrader valve. (Can't say I blame you.... As well, Goodman is not my first choice for installation.)
  12. #9
    Southold, NY
    We all have experience with this valve.................Every damn one is different!
  13. Likes JayMan7 liked this post.
  14. #10
    Mar 2018
    Virginia
    I think you got plenty of good answers...especially from 600a! Do you really need someone to be ultra experienced on removing a Schrader from that coil?
    I mean I just donít see how itís that big of a deal.
  15. Likes R600a liked this post.
  16. #11
    Jul 2019
    Quote Originally Posted by JayMan7 View Post
    Yeah I don't see any advantage in leaving it in since it doesn't make it easier to change the TXV in the future. Now we need to get the darn factories to put Schrader valves under the high pressure safety so that you don't have to recover the charge to change the silly thing out.
  17. #12
    Mar 2018
    Virginia
    Oh man thatís the truth!!!
    Apparently manufacturers are trying to abide by the ďno valve in series with a safetyĒ rule but that rule needs to be modified to allow schraders.
    I think itís very dangerous to technicians to leave them guessing all the time whether or not thereís a schrader under the damn switch.
  18. Likes R600a liked this post.
  19. #13
    Mar 2018
    Virginia
    I use this on any switch thatís a stub or on a stub
  20. #14
    May 2011
    Thanks everyone! Have a great weekend!!! Schrader valve will be removed.
