Results 1 to 20 of 22
Thread: P-trap location (you guys were right installer messed up)
    Feb 2021
    So all the shit i got for hiring a guy off Craigslist was fair. Its Summer now (in northern cali) So i started using cool mode. The other day my wifey noticed a bunch of water leaking out of the return vent(a few cups of water). After some research, I'm pretty sure it's the lack of a P trap (drain is on negative side). The drain pipe sucks in water when the system is running. I don't think(?) there is enough room to install a trap directly at the drain and keep a downward slope(see picture).
    Question:
    Can the trap be installed on the other side of the AHU just past the secondary drain pan wall?
    If not what are my options?
    Will I have to have someone come out and extend the height of the return, raise the AHU, and then install the trap?
    I'm just happy this didn't happen in the middle of the night or my ceiling would have been done for.
    I can admit when I'm wrong, Y'all where right. Please help!
    Jan 2020
    Winnipeg Canada
    A trap should be able to be installed in the run that's shown
    You don't squat with your spurs on.
    And you NEVER put the torches away before pressure testing.
  3. Likes R600a, Mr Bill liked this post.
  4. #3
    Jul 2019
    Oklahoma home its in the name
    A real tech will have no problem fitting a trap in that location.
    Sent from the Okie state usin Tapatalk
  5. Likes Mr Bill liked this post.
  6. #4
    Jan 2014
    New England
    Keep the trap inside the auxiliary drain pan, in case something freaky happens to it over time such as develop a hair line crack from heat or whatever. At least the condensate from that crack will drip into the pan instead of onto the attic floor and who knows what’s underneath
  7. Likes R600a, Mr Bill liked this post.
  8. #5
    Jul 2019
    Also its best to have any wet insulation, sheetrock and wood dry within 48 hours to prevent biological growth.
  9. #6
    Jul 2011
    DFW, TX.
    I see a street 90° in you future. Easy job.
    Sent from my LM-G820 using Tapatalk
  10. #7
    Athens, Ohio
    Perhaps it’s time to just hire a professional contractor to inspect the whole thing instead of looking for answers online.
    Site member map HERE!
  11. Likes pecmsg, VTP99, R600a liked this post.
  12. #8
    Southold, NY
    Who screwed up
    The purchaser of the equipment
    The installing contractor
    The duct contractor
    The electrician
    https://hvac-talk.com/vbb/threads/22...m-just-blew-up
    https://hvac-talk.com/vbb/threads/22...-would-you-use
    https://hvac-talk.com/vbb/threads/2227001-plenum-size
    You've been at this with multiple issues for what 3, 4 months? My god 1/2 of the warranty is almost over if there is any warranty after the blame game gets played!
  13. Likes kdean1, R600a liked this post.
  14. #9
    Southold, NY
    Quote Originally Posted by kdean1 View Post
    But he saved so much with side job Bob!
  15. Likes kdean1, CEAS-AC-TECH liked this post.
  16. #10
    Houston,Texas
    Not to mention, plastic pan, wood for stands, no Armaflex on the drain line, and no trap. AH have negative pressures in the drain pan area, so they usually only drain when the system turns off.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
  17. Likes kdean1 liked this post.
  18. #11
    Oct 2011
    Culver, Oregon (Central OR)
    Always a Goodman.
  19. Likes R600a liked this post.
  20. #12
    Jan 2010
    Quote Originally Posted by Adlerberts-Protege View Post
    Always a Goodman.
    Why is that 🤔
  21. Likes R600a liked this post.
  22. #13
    Southold, NY
    Why is that ��
    Cheep
    Cheaper
    Cheapest!
  23. Likes CEAS-AC-TECH, R600a liked this post.
  24. #14
    Feb 2021
    I tried to call a few but they don't want to work on someone else's stuff (I guess I could stop telling them about the bad install) the original guy has been back to the house 3 times already
  25. #15
    Feb 2021
    Cheep
    Cheaper
    Cheapest!
    Hey man that's the AVPTC with a GSZC
  26. #16
    Feb 2021
    It wasn't a side job. It was a licensed Goodman dealer.
  27. #17
    Feb 2021
    Who screwed up
    The duct contractor
    The electrician
    I screwed up cuz I was trying to save $. In all fairness he was a state licensed Goodman dealer.
  28. #18
    Southold, NY
    Quote Originally Posted by BadHomeOwner View Post
    Licensed doesnt mean squat.................Qualified is what you should have looked for!
  29. #19
    Southold, NY
    Me for trying to save $?
    And now you see why you get the responses you get.
    You've wasted $ and have probably shortened the life of the unit.
  30. #20
    Feb 2021
    I don't mind putting up with the rude people on here. There is always one or two people who actually respond with helpful information. Even the responses from the rude people can be helpful. I said I was trying to save $$, not that I spent $. Price talk is not illegal on this forum.
  31. Likes ksefan liked this post.
