Results 1 to 4 of 4
Thread: Humidity goes up with temperature in split ducted system
    Mar 2010
    Hi There Forum,
    In our main large clean room we often see that the relative humidity goes up when the air temperature drops and I'm familiar with the reasons for this.
    But we have another room with a split ducted AC system that has a reheat coil on the supply air, when I look at the graph it clearly shows humidity rising with and tracking with the rise in temperature in the room and I'm trying to understand the physics of this.
    Is it because the air is enclosed within a duct and that the moisture can't really escape from the air unlike the larger open clean room space?.
    TIA
    Multivits
    Probably because the evap coil is not dry when the heat comes on after a dehumidify call.
  3. Likes jmlandru liked this post.
  4. #3
    Mar 2010
    Thanks for the reply, I'm not 100% sure that the system has a dehumidification function and will check to see if it does and that it is enabled.
  5. Likes beenthere liked this post.
  6. #4
    Mar 2010
    Quote Originally Posted by multivits View Post
    It's confirmed that this split ducted system has no dehumidification function.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
