Results 1 to 20 of 28
Thread: What on Earth is this sound coming from the compressor? (video)
    Mar 2002
    Concord, CA
    Question What on Earth is this sound coming from the compressor? (video)
    Goodman GSX140251KA / 1503148998
    Amp draw and voltage at the contactor were steady. I believe it was drawing about 7 amps with an RLA of 10.9. Pressures were steady as well at 139 and 370. SH and SC were 9.9 and 1.4 respectively.
    Jul 2019
    Oklahoma home its in the name
    That is weird. I don't have a clue.
    Sent from the Okie state usin Tapatalk
    Jul 2019
    My wife says aliens are trying to communicate with you through it.
  4. Likes CEAS-AC-TECH liked this post.
  5. #4
    Mar 2002
    Concord, CA
    That's weird. Normally they use the fillings in my teeth.
  6. Likes R600a, CEAS-AC-TECH liked this post.
  7. #5
    Jan 2014
    New England
    Chattering contactor? What metering device you have? Goodman install guide says for TXV superheat and subcooling 7-9 degrees.
  8. Likes Paul Benkovitz liked this post.
  9. #6
    Mar 2002
    Concord, CA
    It was definitely coming from the compressor.
  10. #7
    Jan 2014
    New England
    Check the wires at the compressor itself? Run system with the outdoor fan motor deenergised for a short time to try to isolate. Does it have a start assist kit installed? What does the points look like at the contactor?
  11. Likes R600a liked this post.
  12. #8
    Jul 2019
    The only thing I have seen do anything sorta similar was a trane with the suction lines passing under the coil and was rubbing in a cyclic pattern but it wasn't nearly as on and off.
  13. #9
    Jan 2020
    Winnipeg Canada
    That sounds like a pin is about to burn off the compressor. Let's not talk about how I know this
    You don't squat with your spurs on.
    And you NEVER put the torches away before pressure testing.
  14. Likes CEAS-AC-TECH, Iamwildbill liked this post.
  15. #10
    Mar 2002
    Concord, CA
    Quote Originally Posted by Restaurant mech View Post
    Are you saying that the Fusite could be failing? It's been making that noise since at least last year.
    I share this link about Fusites for my customer who may be reading this thread and for anyone else that doesn't know the term Fusite.
  16. #11
    Jan 2020
    Winnipeg Canada
    I'm saying that I hear 60 hertz . Likely not the fusite itself at this point but it sounds like an intermittent connection.
    I'd be pulling the plug off the compressor and having a really good look at all connections.
    Sometimes you can have a connector just tight enough to start the compressor, but once the compressor runs and vibrates a little the connection comes loose and you can hear the miniature arcing
  17. Likes jacob-k liked this post.
  18. #12
    Jun 2012
    Northern NV
    Intermittent flood back.... My guess from the sound. TXV hunting?
    Sound is no load/full load.
    “A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.”
    ― Robert A. Heinlein
  19. #13
    Feb 2013
    Sonora, California, United States
    I once put my elbow on a cap while trying to amp draw a motor....
    It lit me up internally the same way that compressor sounds.....
    Look at all the wiring, make sure nothing is arcing, make sure there is no wires hooked up wrong at contactor, replace the cap and make sure its wired correctly, add a hard start.
    I would also be suspicious of the contactor.
    pull the compressor harness and make sure there's no issues with it.
  20. Likes R600a liked this post.
  21. #14
    Aug 2009
    Beatrice, NE
    You have a SH of 10 and SC of 1.4? Sounds to me like a compressor that is starving and every once in a while it gets enough freon to quiet down. Check your discharge temp, my guess is it is running high. I have heard some scroll rattle/knock when they are running low on juice.
  22. #15
    Jul 2019
    Quote Originally Posted by BNME8EZ View Post
    That just reminded me of a crazy tenant that was telling me about how some other tech came out and over charged his ac so bad that the rod was knocking. It was a scroll.
  23. #16
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by R600a View Post
    Yeah funny how that can work isn't it.. In this case even with a fixed MD 1.4 SC is low. The other thing could be poor air flow which 10 SH with that low of SC could indicate.
  24. Likes R600a liked this post.
  25. #17
    May 2014
    Bay Area California
    Sounds exactly like a scroll with an unloader. But I've never seen that on a smaller unit.
  26. Likes R600a, jgjn liked this post.
  27. #18
    Hopefully its registered so you get that compressor free
  28. #19
    Mar 2002
    Concord, CA
    California has a decades-old law that prohibits registration to qualify for the full warranty. I've successfully processed a number of 6-10 warranties on equipment that wasn't registered.
    Most techs locally either don't know about the law or pretend that they don't. A manager of a local Rheem wholesaler claimed he didn't know about it. A rep at Lennox's warranty department pretty much did the same. Convenient.
  29. Likes jacob-k liked this post.
  30. #20
    Man .... we are running out of GOOD things to say about California
