Thread: ADP B Series Heating Coil Water Leak
    May 2021
    Hello,
    I have an ADP BCRM series internal air handler. During the winter, some water was left in the heating (water) coil, it froze and cracked. There is now a hole in the bottom 'U' pipe (it looks like 3/8" copper?). I attached a photo but I'm not sure if I can post it. Can that be repaired or must the whole heater coil unit be replaced, or even worse the whole air handler - which is impossible as there's no access to the attic large enough. How big a job is each option ?
    Ideally, it's something I can patch with epoxy putty, UV cure epoxy etc. to last 12 months until I may be doing a remodel and a pro can do it properly.
    thanks.
    Jul 2019
    Oklahoma home its in the name
    Any halfway decent technician should be able to repair that with a little bit of braze.
    Sent from the Okie state usin Tapatalk
    Southold, NY
    Quote Originally Posted by R600a View Post
    As long as that's the only leak!
  4. Likes R600a liked this post.
  5. #4
    Jun 2014
    Dover, DE
    Should be brazed. Epoxy will likely not work.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
  6. Likes R600a liked this post.
