Results 1 to 7 of 7
Thread: Condenser location import- sun/shade?
    Apr 2021
    north central Indiana
    This unit is ONLY servicing the upstairs bedrooms. Rooms will be unoccupied until dark, or nearly dark.
    South of house is already the first of May in shade after 7PM
    In winter I estimate 20 deg solar insolation gain by location in sunlight- on sunny day. (I know heat is not measured in degrees)
    Do you guys take this stuff into account when locating a condenser?
    Southold, NY
    No
  3. Likes kdean1 liked this post.
  4. #3
    I do but it's really a minor element of it all. If there is shade available, and locating the unit in the shade won't negatively impact any of the other considerations, I will try to locate in shade rather than in sun.
    A possible problem with locating in shade is that more stuff tends to grow on the condensing unit. And if the shade is in a dead-air sort of area I think it tends to collect more dirt.
    PHM
    Quote Originally Posted by ekid View Post
    Do you guys take this stuff into account "when locating a condenser" ?
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  5. Likes R600a liked this post.
  6. #4
    Jul 2019
    Oklahoma home its in the name
    PHM
    If for no other reason than us AC guys like working in the shade.
    Sent from the Okie state usin Tapatalk
  7. #5
    Apr 2021
    "won't negatively impact any of the other considerations, I will try to locate in shade rather than in sun."
    Can you develop that thought a little?
    How about winter, with temp near freezing point of water? I guess condensation of water is outside then. Is it a problem?
  8. #6
    Aug 2009
    Beatrice, NE
    Since you are talking both winter and summer conditions I am assuming you are talking about a heat pump. A more important consideration if that is the case is does snow tend to drift in that location. That could cause defrost issues.
  9. Likes R600a liked this post.
  10. #7
    Apr 2021
    " am assuming you are talking about a heat pump"
    I guess so. Mini-split, more specifically. But really the AC cooling in summer is primary.
    I can sleep in 50-60 deg room (with electric blanket.)
