+ Reply to Thread
Results 1 to 11 of 11
Thread: Malco hole cutter
    NC
    Malco hole cutter
    Can the bit on the Malco hole cutter be sharpened? I know how to sharpen a drill bit but this bit cuts on the side not sure how or even if can be sharpened.
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    I just replace them.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  3. Likes vin lashon liked this post.
  4. #3
    Deep Southeast
    Not worth the time. Replacement.
  5. Likes R600a liked this post.
  6. #4
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by vin lashon View Post
    I'm pretty sure you can't sharpen the side of a drill bit now if it was an actual milling bit that would be a different story.
  7. Likes vin lashon liked this post.
  8. #5
    Jan 2012
    Broomall, PA
    I always drill the initial hole with a zip screw when drilling into sheet metal. The tip of the drill bit lasts much longer.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Helpful Calcs, tips, tricks on my YouTube channel: https://www.youtube.com/channel/UCgm...TUTAdKmqRiTDEg
  9. Likes vin lashon liked this post.
  10. #6
    Jan 2015
    Bellevue, Washington, United States
    Quote Originally Posted by STEVEusaPA View Post
    x2. Zip screws are useful in many ways.
    To answer your question you can sharpen it if your careful and get the angle just right. But as other's have said it's usually not worth the time.
  11. #7
    R600a's Avatar
    Jul 2019
    Now if you are meticulous enough to save up a bunch of them like say maybe 10 of them you could probably take them to Fastenal and send them in to be sharpened. But the problem is if it's the side that's dull and they aren't cutting the circle very well then it's not going to do anything because they only sharpen the tips for drilling.
  12. #8
    NC
    Point taken. Already replaced.
  13. Likes R600a, JayMan7 liked this post.
  14. #9
    Mar 2018
    Virginia
    The problem is the tip isn’t the real issue. It cuts on the side and that’s what you can’t sharpen. Honestly a new bit is something your company should buy you.
    "I think Quantum tunneling would work great... "
    "Call a technician for God's sake. Or we'll see you on the news or the Dark Side of the Moon."
  15. Likes R600a liked this post.
  16. #10
    Hurst11 is offline Professional Member/Membership Committee
    May 2020
    Haskell Oklahoma
    I don’t see why they couldn’t be sharpened being they have to be sharpened to work in the first place. Like already mentioned, prolly not worth it but would be neat to know how they do it.
  17. #11
    Mar 2018
    Virginia
    Quote Originally Posted by Hurst11 View Post
    Well they are carbide for one thing. I do have a drill bit sharpener that I believe would sharpen the tip. But my guess is the side cutting edge is being done by machines in a factory that are worth more than the homes we live in so yeah it’s kinda outside diy range
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
