Results 21 to 40 of 62
Thread: Help explaining 208v system with compressor & capacitors
  1. #21
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by flangatang7 View Post
    EDIT: For those looking for more information see below.
    Thank you!
    COMPRESSOR WHILST RUNNING
    these 3 don't tell you much except they are energized (hot)
    Ground to #5 on Potential Relay = 120v
    Ground to #1 on Potential Relay = 120v
    Ground to # 2 on Potential Relay = 120v
    Start Capacitor
    Ground to either terminal = 120v
    L1 (Common) to either terminal = 208v This tells you the terminals are powered through L2
    Run Capacitor
    Ground to either terminal = 208v
    L1 (Common) to either terminal 250v yep..... 250v
    L1 (Common) to Start winding = 250v
    L1 (Common) to Run winding = 208v Shows common is powered by L1, run is powered by L2
    L2 to Run winding = 0V
    proof of above, R and L2 are the same potential
    You should really take a class on electrical theory or read up on it, or get a senior tech to help you understand what you are looking at. It will also keep you safer!
  2. Likes flangatang7 liked this post.
  3. #22
    Mar 2015
    Medford, N.Y.
    Both windings are both powered by L1 & L2.
  4. Likes flangatang7 liked this post.
  5. #23
    Apr 2021
    Canada
    Quote Originally Posted by BNME8EZ View Post
    100% electrical has never been my strong point coming from Australia where we don't use 208v it's a little harder. I am trying and taking time out to learn though. Will see if I can find some classes.
    Can you explain to me what #5 does on the potential relay? All I can say for certain is it has 120v coming in from L1.
    Thanks for your response!
  6. #24
    Aug 2009
    Beatrice, NE
    Terminal 5 is one end of the relay coil, it is the same power leg as C terminal on the compressor.
  7. Likes flangatang7 liked this post.
  8. #25
    Virginia
    If you took that relay apart , you would be like .... oh .... so thats how it works
    Its just a magnetic coil , and a set of points
    The magnetic coil kicks the points open , and that drops out the Start Cap
  9. Likes flangatang7 liked this post.
  10. #26
    Apr 2021
    Canada
    Quote Originally Posted by Snapperhead View Post
    Yep!
    Is it fair to say that the contact on terminal 1 opens once compressor reaches 75% running capacity?
  11. #27
    Sep 2013
    Wi
    The voltage is generated in the start winding. If the pick up voltage of your relay is higher than what you measure it won't pick up. if you take 80% of it you are close to the proper pu voltage. I have used potential relays on farm motors to replace the switches in the end caps.
  12. #28
    Jan 2010
    Would that be the centrifugal switches ?
  13. #29
    Jul 2019
    Oklahoma home its in the name
    I have gotten bad motors straight out the box ....
    Maybe you finally got yours
    I have got several over the last couple years.
    Sent from the Okie state usin Tapatalk
  14. #30
    Mar 2021
    Is 208v in canada a twin phase circuit?
  15. #31
    Southold, NY
    Quote Originally Posted by MadeInAustralia View Post
    Here in the States we use the term single phase or 3 phase. 208 / 230 can be both. (I know gets confusing) 3 phase does not get start components.
  16. #32
    Southold, NY
    A little reading material
    Hope it helps
  17. Likes R600a liked this post.
  18. #33
    Mar 2021
    So you call a circuit with active and neutral 1ph
    and also call a circuit between two phases of a three phase supply 1ph as well?
  19. #34
    Jan 2010
    YES
  20. #35
    Southold, NY
    Our 115 Volt can use any of the 3 phases with a Neutral. Phase to Phase is 208 / 230 Single phase
    I believe you use 230 volt for standard power supply. Each leg to ground shows 110 volts?
  21. #36
    Jan 2010
  22. #37
    Southold, NY
    Now I'm confused!
  23. #38
    Mar 2021
    415v 3ph standard supply, 230 any phase to neutral.
  24. #39
    Southold, NY
    OK that's the difference.
  25. #40
    Mar 2021
    maneurope made a 415v phase to phase sump heater back in the day.
