Results 1 to 20 of 24
Thread: Electrical curiosities, take 2
    Aug 2019
    Maryland
    In this episode of “Is that how it’s supposed to be”
    On today’s service call I saw the common side of a low voltage coil hooked up to the ground…
    last time I made an assumption about how I think it should be.. I was wrong.. so I won’t make any assumptions and will just wait for the yays or nays
    Jul 2019
    Oklahoma home its in the name
    I have seen the common side of the ac contactor hooked to the lineset and it worked too .
    Sent from the Okie state usin Tapatalk
  3. Likes lions_lair liked this post.
  4. #3
    Dec 2006
    Vancouver, B.C.
    It works like that but should be run back to the common of the transformer. At that point it can go to ground.
    The chassis of the unit is not designed to be a current carrying device. Also, if the transformer does not make a good connection to the chassis of the unit then your voltage to the contractor can get inconsistent and poor results will happen. You don’t want to be the guy who causes the customers inconvenience or be the cause of that bill.
    Quickly, I must hurry, for there go my people and I am their leader!
  5. Likes R600a liked this post.
  6. #4
    Dec 2006
    Vancouver, B.C.
    Quote Originally Posted by R600a View Post
    I’ve seen electrical arc blast it’s way through a copper pipe before. I hope they used some quality electrical tape to secure that connection.
  7. Likes R600a liked this post.
  8. #5
    Jul 2019
    Quote Originally Posted by thatguy View Post
    That aught to be fun with flammable refrigerants.
  9. #6
    Did you look at the common side of the transformer? It was likely connected to the ground as well.
    Is what you saw Right? No; of course not.
    Is it legal? No; of course not.
    Will it work? Almost certainly.
    Did the common wire have continuity end-to-end?
    How difficult would it be to run a new wire from this coil you saw and the transformer location? <g>
    BTW: What did the wiring diagram show?
    PHM
    Quote Originally Posted by Sabr7 View Post
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  10. Likes R600a, STEVEusaPA liked this post.
  11. #7
    Mar 2015
    Medford, N.Y.
    As PHM asked, what does the wiring diagram show for the factory xformer set up?
  12. #8
    Apr 2021
    (Logged in as wrong user)
  13. #9
    Southold, NY
    Quote Originally Posted by Shakur View Post
    Wiring diagram? No such luxuries at this run down spot. Hard enough getting the model and serial
    Internet?
  14. #10
    Apr 2021
    Internet?
    Yeah what the heck , had problems logging in to the server
  15. #11
    Aug 2019
    Maryland
    PHM
    Okay, logged in now..
    As I was saying, no wiring diagram
  16. #12
    Southold, NY
    Sometimes the Common is broken on safety devices.
    There should always be a common wire going back to the transformer, there is may be grounded!
  17. #13
    The rest of the questions are important too. <g>
    PHM
    PHM
  18. #14
    Aug 2019
    Maryland
    PHM
    End to end continuity - yes
    Difficulty running new wire - not hard at all
    Will be out returning with a mechanic (I’m an apprentice) and I’ll see what he does
  19. #15
    Mar 2018
    Kansas Flatlands
    Lennox has been grounding the common since probably the mid 70's
  20. Likes R600a, dieseldude liked this post.
  21. #16
    Jul 2019
    Quote Originally Posted by theoldscroll View Post
    I was grounded commonly for not doing my homework most of my childhood.
  22. #17
    Jul 2013
    Richmond, VA
    I chose to take detention over homework, took up less of my time.
    I've grounded common in a pinch, like having a shorted thermostat wire but not enough any spare wires. 24VAC common is almost always earth grounded anyway, so in my opinion it doesn't really matter.
    Everything I’m going to say today are my conclusions and my opinions, my opinions are based on my education, my training, my experience. Different people have different experiences, so they have different opinions and I make no claim that my opinion has its origin in the mind greatness. - Paul Harrell
  23. Likes R600a liked this post.
  24. #18
    Jun 2012
    Northern NV
    One exception I know of to chassis carrying "current" is return path for the flame sensor.
    “A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.”
    ― Robert A. Heinlein
  25. Likes theoldscroll, R600a, heatingman liked this post.
  26. #19
    Nov 2010
    Cincinnati, OH
    The common side is almost always bonded to ground, the ones that aren't you'll read 12v to ground on both sides of the secondary, you will still have 24v total and it will work. I don't know how all manufactures do it but but some have a jumper straight from the common side of the transformer.
    I was skeptical the first time someone told me that too but you can check for yourself. Take a transformer on a bench(i think a lot of the transformers themselves bond to their mount in the unit) and measure secondary to 120v ground, you'll get 12v each, then take one side of the secondary and bond it to said ground, you'll get 24v to ground on the other side. Neutral in 120v is similar it is a current carrying conductor but it only reads 0v to ground because its bonded to ground.
  27. #20
    Virginia
    Im thinking I see grounded transformers in Commercial units more often than Resi
