Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
Thread: Yoshimasa sushi display
  1. #41
    Oct 2011
    Chicagoland Area
    Don't worry he'll find it eventually.
    I don't know...I saw a missing compressor ad on the back of a milk carton today. Probably already part of a refrigeration trafficking ring...
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
  2. Likes R600a, VTP99 liked this post.
  3. #42
    Aug 2013
    Las Vegas, NV
    Manufacturer didn’t really want to talk about saturation temp , subcooling , or superheat. They were only concerned about frost line and pressures. Which doesn’t make sense
  4. #43
    Aug 2013
    Las Vegas, NV
    The compressor stopped “running”. So we were able to catch up to it.
  5. Likes R600a, VTP99 liked this post.
  6. #44
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by smsmechanical View Post
    Frost line is an old school rule of thumb way to charge small self contained units. Put enough gas in to get frost to the compressor and then bleed some off until the frost line recedes about 6" from the compressor.
  7. Likes R600a liked this post.
  8. #45
    Sep 2020
    hahaha fat fingers must of hit it tumbing throught. I must say it is a fun read!
  9. Likes R600a liked this post.
  10. #46
    Aug 2013
    Las Vegas, NV
    I’ll update everyone once we get this figured out.
  11. Likes R600a liked this post.
  12. #47
    Sep 2020
    I never worked on this type of unit. But in a past life I had the miss pleasure of working on a lot of PTAC unit with AEV.
    AEV work by closing the valve the hoter the box and open the colder it gets.
    When you go back w/ a compressor and AEV, I would bring Ice bags put them in the case
    to bring down the box temp.
    After the chang the box temp should be close to 40* start charging vaper slowly
    and I do mean slow till you see frost just starting to form @ the end of the coil then mark the top of the AEV in line with a mark on the head you can slowly turn the screw 1/8" turn tracking the unit temp and psi set to temp of box minus evap temp. Well I know it worked for PTAC units haha
  13. #48
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by tt/rich View Post
    What are you talking about with PTAC's and "box temperature"? When I think of of a PTAC, I think of the glorified window air-conditioners that they have at the Motel 6. Are you talking about a walk-in cooler with a self contained package deal that sit on top? Yeah, that sounds like it would suck!
    I've worked on a couple of glycol beer chillers that had AXV's. If the glycol (or whatever it is that you are trying to cool) is warm, it can take an excruciatingly long time for it to start coming down to temperature. They sometimes need a full 24 hours to find out if the stupid thing is working or not. It doesn't make a whole lot of sense why any manufacturer would choose one of these.
    Luckily from what I remember about these sushi cases, since it's really just copper pipes that we're trying to cool down, with no fan blowing across them or anything, I don't think it takes very long to see if the system is working properly.
    If at First You Don't Succeed, Skydiving Is Not for You.
  14. Likes R600a liked this post.
  15. #49
    Southold, NY
    W T F ?
  16. #50
    Apr 2003
    Maple Grove, MN
    Actually, I think I get why sushi cases use AXV's. On these things, the copper pipes that run through the cases need to be covered in frost, without being too cold and without the compressor ever shutting off (otherwise the frost would melt and drip all over the sushi). An AXV on a system like this that has a fairly consistent load will allow the refrigerant to run through the pipes at a nice constant pressure, which means it will follow the PT chart relationship to maintain a nice even temperature.
    The way in which the AXV works, in that it opens up as the load gets less, means that you can't just maintain a clear sight glass coming out of the receiver. You actually want the thing to start running out of refrigerant as the case gets cold, otherwise you will slug the compressor. That's why you slowly charge it up while watching the frost line, and you stop adding refrigerant as soon as the frost starts getting close to the compressor.
  17. Likes R600a liked this post.
  18. #51
    Jul 2019
    Oklahoma home its in the name
    Also no air movement to dehydrate the Sushi.
    Sent from the Okie state usin Tapatalk
  19. #52
    Jan 2010
    Sea to Sky
    Quote Originally Posted by R600a View Post
    You don't like Sushi Jerky?
    Sent from my SM-G965W using Tapatalk
  20. #53
    Jul 2019
    Quote Originally Posted by BALloyd View Post
    I don't like sushi. For that matter I don't like sea food much although shrimp is good.
