Results 21 to 26 of 26
Thread: Subcooling not increasing.
  1. #21
    In general; if adding refrigerant to an operating refrigeration system does not increase liquid subcooling - the condenser's liquid capacity has not been reached yet. <g>
    PHM
    Quote Originally Posted by Laeeq421 View Post
    Hi experts. I can use some guidance.
    Charging a txv system with subcooling is simple.
    The problem I ran in today was really weird. The unit had low on gas and was freezing ice.
    After melting all ice I started adding refrigerant.
    The suction line gauge showed the pressure at 100 means temp was around 30deg or so so no wonder it was freezing. I added 410a as system needed the charge.
    My pressure increased. I charged till about 125psi on suction line and ~300psi on liquid line. My temperature on liquid line remained high. About 96deg (saturated temperature in the middle of condenser coil -reading on high side gage) and 94deg on liquid line temp. That’s just 2deg subcooling. My outside temp was around 81deg. Even adding refrigerant don’t help increasing the subcooling. This is odd. It should be simple but in this unit the liquid line temp increasing with the charge. What is wrong.
    It’s a 10yr old system Rheem 410a. I don’t see subcooling data anywhere on the unit.
    Please help.
    System type split (outside condenser and garage air handler)
    Refrigerant 410a
    Ice was built up on inside air handler and outside by the pilot valve (pic attached)
    No subcooling data
    16seer unit - Rheem 10yr old.
    Attachment 823891
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  2. #22
    Southold, NY
    “saturated temperature in the middle of condenser coil -reading on high side gage”
  3. #23
    Austin, Texas
    You said 81 degrees ambient and 103 degrees condenser discharge. On a 16 SEER system, that condemser coil is NOT clean!
  4. #24
    Apr 2021
    Nope. Air handler coil
  5. #25
    Aug 2019
    Maryland
    How can you say it’s no liquid line restriction without taking superheat readings
  6. Dislikes VTP99 disliked this post.
  7. #26
    Deep Southeast
    Some more data.
    Yes TXV system. I checked by removing cover.
    Before I got to the job site the costumer had the AC turned off for atleast 24hours so all ice was fully melted. Coil was clean
    When I got to the site and charged the system (yes slowly), it started cooling with the gauge readings I provided (125 and ~300). The house cooled to 75deg or so inside temp.
    I didn’t check the superheat but will measure today.
    The unit has been cooling for 24hours now with no freezing issues and the house is cooling (75deg inside).
    Inside blower airflow is good (running full speed) and airflow out of ducts are good also.
    The difference in ambient temp and the air blowing out of outside condenser was about 22 degrees so it is removing heat.
    Both indoor and outdoor coils were clean. I did change the inside filter just for kicks.
    Nonrestriction on liquid line. Temp outside before dryer is same as after dryer and also same by air handler.
    With all those the subcooling won’t come up. With more charge the head pressure keeps increasing but also the liquid line temp keeping the subcooling low. I don’t want to overcharge.
    Yes my gauge is good.
    Please help.
    You really aren't giving enough information for anyone to help you with the diagnosis, but it sounds like to me that the issue was low on charge. And I'll speculate that when you attempted to add more refrigerant, the indoor temp was below 70°, which can create problems when charging. I've had similar results and returned when temps were warmer and was able to finish charging as expected.
    An example of the kind of information that would help us help you:
    Name:  MQ Data points.PNG
