Calling my electric teacher’s bluff
Context: this is the 24 volt side of a 120 input transformer.
So he said the last line will cause a direct short. Really? One line is hot and neutral so if there is ever a direct connection, I’m thinking it would be a return path for the power.
If it were 3 phase, and phase to phase connection then I would agree.
If I’m wrong, I’m all ears for an explanation.
He's correct
Sent from my Moto Z (2) using Tapatalk
Post Likes - 3 Likes, 0 Dislikes
Post Likes - 1 Likes, 0 Dislikes
Yup a short..... Why do you want that line there?
Who’s to blame?... if you’re looking for the guilty, you need only look into a mirror. I know why you did it. I know you were afraid. Who wouldn’t be? War, terror, disease. There were a myriad of problems which conspired to corrupt your reason and rob you of your common sense. Fear got the best of you, and in your panic you turned to the now high chancellor, Adam Sutler. He promised you order, he promised you peace, and all he demanded in return was your silent, obedient consent. V for Vendetta
Would this blow the transformer
Originally Posted by
Elfshadow
I didn’t have it there in class, but someone else had it so I added it to mine just to pose this question
Sabr7
Yes it would.
Post Likes - 2 Likes, 0 Dislikes
It’s starting to make sense now, what threw me off was thinking that the neutral line returns unused voltage. This is true but only trace amounts.
You will definitely come to the realization that all things electrical operate on magic smoke, let that magic smoke out and the electric item will cease to operate.
The problem is related to how you calculate amps.
You really need to figure it out yourself though so that it sticks.
Sabr7
Full voltage, not trace. Need more time on basic electricity.
The generic simple thing I always said was “something needs to consume or eat the voltage before it gets back to the neutral.” Weather it is a light bulb a coil on a contactor or what have you. Just my easy way to remember it.
Sabr7
Not exactly.
Neutral completes the circuit. Without it, nothing happens.
Need 3 things.
Source, path, load.
Source in this case is the transformer. But could be a battery, utility, generator etc...
Path is the physical wires (and case ground in a car or similar) and any switches.
Load is anything consuming power
Any complete path connected to a source without a load is a short circuit.
Think of the circuit like a circle.
Complete the circle with a load between the 2 sides of the source
Thanks for your explanations, this sheds light on my lack of clarity on the neutral, and honestly even googling the ‘purpose of the neutral wire’ doesn’t add any clarity
heatingman
Not exactly.
Need 3 things.
Source, path, load.
Got it, this, coupled with the other explanations makes me understand. I think I was looking into it more than what’s necessary.
Always complete the circuit and give the electricity a job to do
Sabr7
Listen. No rush. Take your time, ask questions. The only dumb question is the one you don’t ask.
Quite literally having a solid grasp on the basic concepts of how electricity works is the most important thing you can do to ensure success in this career.
Lots of knowledge here to glom onto.
We were all where you are at some point.
Hopefully your getting lots of lab time in your school
Sabr7
There must be a resistance between the got leg and the neutral in order for it not to become a direct short.. light bulb, motor, etc etc
A saturated coil is a happy coil
Say "I just need a little Freon" one more time!
No such thing as unused voltage.
Why is it that those who complain the most contribute the least?
MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
heatingman
Except the guru that graced us for a while. He was master electrician and service tech before he left the womb.
