+ Reply to Thread
Thread: So many things wrong on one house.
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    There was no conduit on the 240 volt wires going to the condensing unit. Rodents were using the line set hole as an attic access and the dryer vent was just blowing out in the attic.
    I was there on a no cooling call because the thermostat wire had been chewed through.
    Needless to say I replaced the wiring with a new whip and blew some spray foam in the hole that the mice had been using before replacing the thermostat wire.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
    R600a's Avatar
    Jul 2019
    But wait there's more.
    It also called for a Max 30 amp fuse and it had 60 amp fuses on it. Of course I had to replace those.
  3. Likes mofotech liked this post.
  4. #3
    Apr 2006
    Tyler, Tx
    What about the temporary suction line drier? You replace that?
    Philippians 4:13
    I can do all things in him that strengthen me.
    Apostle Paul inspired by GOD.
  5. #4
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by Artietech View Post
    Nope opening the system costs too much and for a pile like that it's not worth it. Now if I had to have the system open for some reason I would definitely remove it.
    I hate to admit this but a few years ago when I first started out I helped put a new furnace and coil in that system and we did not remove the filter. My boss should have known better and had me do it because I was just starting out and didn't know anything.
  6. Likes mofotech liked this post.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
