Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: High Suction and Discharge in Heat Mode
  1. #41
    Chicago area
    Did you check the charge in cooling mode?
    Based on OA temp, and indoor wet bulb?
    14 degree of superheat may be a bit too low.
    Target Superheat :
    ((Indoor wet bulb x3)-80-oat)/2
  2. #42
    Jan 2021
    South Texas
    Pictures of the air handler with the cover off show a total of 96 tubes on the ARUF25b and 108 tubes on the ASPT25b. Around 12 percent more.
    At one time it was stated that with an acceptable charge that worked in heating, the cool numbers showed high superheat and high subcooling. Possibly the piston in the air handler is too small. Switching it to a TXV and using the minimum charge would be the only possible solution with the existing coil.
    If the customer is looking for 16 SEER, a new air handler would be required, if not a TXV on the indoor coil would be my next step.
  3. #43
    Nov 2011
    Quote Originally Posted by 3rdcoast View Post
    Ditto...
    Goodman expanded data for the ASPT31 match shows 153 psi suction at AHRI rating conditions...lots of luck with that.
  4. #44
    Aug 2009
    Beatrice, NE
    Putting a new coil w/TXV would be the best option, adding a TXV with a charge robber would be 2nd, adding a TXV will help but I don't see it compensating for volumetric coil differences.
    When the Trane XL19i first came out I put one it my house and inadvertently put in the wrong size TXV coil. I was able to adjust the charge and get it to work but not like it should have. Later I replaced the coil and achieved much better operation out of it. So in that case the TXV was not enough to compensate for coil volume difference. I think the only thing that saved me at the time was the 19i's were R-22 which seems to be much more forgiving on charging issues.
  5. #45
    5,000 ft
    Off the wall question.
    Is the electric BU heat before the coil and possibly energizing when it shouldn't?
  6. Likes heatingman liked this post.
  7. #46
    Nov 2020
    Denver, Colorado
    When running the unit in cooling, it seems like its overcharged possibly? What was your R/H when the ODT was at 69 degrees, or if you have the Indoor W/B temp, that will work as well.
