Results 21 to 22 of 22
Thread: All bound up
  1. #21
    Jan 2005
    Houston TX
    Okay will go with that. More in pro section
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
  2. #22
    New Jersey
    Quote Originally Posted by ga1279 View Post
    Yes, thanks did that with the unbinding and changing the module the module ftom circuit #1 did bind. Unfortunately you can't get the module. So I guess I doing the superseded EXV change out. Any advice on SB's or TechView data that has to be done when changing out the original valve with the new replacement. At least it isn't as bad as the RTAA valve change out. I did several 400 ton units.
    Hopefully the new valve fits the original body. If the new valve needs to have updated software, it will note that with the new exv. Keep us updated.
    Sent from my ASUS_P00J using Tapatalk
