+ Reply to Thread
Thread: Sanidry Cx Dehumidifier Auto Fan not working
    Dec 2019
    I got a warning that the humidity in my crawl space was over limit...I went in the crawl space and could hear the compressor cycling but just coming on for a min or two and then off. The fan was set to Auto mode (on with compressor) but was never coming on. When i switched the fan to always on, the fan runs...the compressor stays on and the crawlspace properly dehumidifies as it should. So for now i have left the fan on. The folks that installed the unit back in 2015 no longer support it and i can seem to find someone local (lynchburg va) so far. It seens it could only be the control PBC or the switch....before i open the unit and check the switch and output of the board i wanted to know if there is anything else i should check?
    Is there any way to get parts for this if i cant find a local firm?
    Peter
    Dec 2019
    Well it was a rainy day so i went back in and opened it up. It seems the main board is shot. The blue wire that controls the auto fan is connected to a relay on the main board...the relay and surrounding area of the PCB is burned..... The signal never goes turns the fan on. So now just the problem of getting someone to swap it or being able to find a part. Any suggestions on where i can get a part for this unit?
    Madison, WI/Cape Coral, FL
    Does it say where the unit was made? Therma-Stor made these units 10 years ago. No boards in them back then that I know about. Running the fan "on" should not be a problem. Sanidry imported from China after that. You may try Badger Systems for more info on parts.
    Also the fan could be wired with compressor circuit.
    Regards Teddy Bear
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
