Results 21 to 24 of 24
Thread: Severely Undersized Ductless Generating Weird Powder in Drain Pan
  1. #21
    Mar 2021
    Hendersonville NC
    Quote Originally Posted by justin_ View Post
    no they don’t have anything like that in the home (they have a boiler for heat) BUT just to make sure, I will double check to make sure they don’t have any room devices plugged in...
    BUT YES!!! the powder does have shiny flakes in it!!!!
    there is no condensate pump for this ductless unit
    Right in.. I was trying to say I've cleaned that same crap out of 2 qt condo pump reservoirs on regular ducted systems.. never gave it a thought except one time I realize it caused the pump to fail or at least I thought it did
    Sent from my SM-G998U using Tapatalk
    Say "I just need a little Freon" one more time!
  2. #22
    Mar 2021
    Hendersonville NC
    Quote Originally Posted by kdean1 View Post
    Do you always shout in your posts?
    Sorry.. my keyboard gets stuck like that once in a while.. I gave it a good swift shot of nitro and the keys unstuck.. I've spilled too many cups of coffee on it .
  3. #23
    Jan 2020
    Winnipeg Canada
    Boiler for heat could be your culprit. If it's releasing steam it's also likely releasing what I call boiler nasties which is a mixture of water and the remnants of the boiler piping. In other words the black water.
    This steam can actually contain huge amounts of microscopic iron particles that actually remain airborne and will settle on the cold evaporator.
    Then possibly clog up the drain.
    I've never seen a case as bad as you are describing, but I did have one where an air handler was close to the steam vent and the iron in the air rotted out the a coil in 3 years.
    You don't squat with your spurs on.
    And you NEVER put the torches away before pressure testing.
  4. Likes HVACmedic911, BBeerme liked this post.
  5. #24
    May 2011
    romulus, mi
    any of those devices could be stand alone plug in the wall devices
    RTB Mechanical
    734-315-0064
    http://rtbmechanical.com
