Results 1 to 17 of 17
Thread: Most reliable Mechanical Flow switch
    Feb 2005
    Florida
    I have been having a lot of failures with the Penn F261 flow switch recently. Can someone recommend a more reliable mechanical flow switch?
    Not looking for electronic flow switch.
    montreal
    Personally I've used United electric flow switch.
    UE
    From there you can select either differential or other switches
    Envoyé de mon moto g power en utilisant Tapatalk
    montreal
    For paddle there is mcdonnell flow switch.
    I do prefer differential pressure
    Jan 2010
    Sea to Sky
    McDonnell is what I see around here for flow switches usually. Pretty reliable it seems.
    Sent from my SM-G965W using Tapatalk
    Nov 2018
    Paddle style flow switches are old news!!
    I would be installing a differential pressure switch. Much easier to set, easier to replace and more accurate!!
    Apr 2020
    va
    Dp switches are fail unsafe.
    Paddle if installed correctly & calibrated are fail safe.
    Correctly selected and installed electronic are more reliable & fail safe.
    Apr 2010
    McDonnell Miller FS8-W
    Its the only kind I can get from the most convenient place, so I don't have a lot of opinions on other options. But they seem to hold up a lot better than that kind you're talking about. Those Penn ones always seem to be full of water under the cover when I open it up.
    Aug 2019
    LA
    IFM Efector u40100
  9. Likes stanbyyourword, Tech Rob liked this post.
  10. #9
    Apr 2020
    va
    McDonnell Miller FS8-W listed as water tight, dust tight, nema 4x
    Penn F261 only listed as dust tight, nema 3r-4
  11. #10
    Feb 2005
    Florida
    Quote Originally Posted by CHAINIK View Post
    I've had the seal leak on the Penn's, the glycol ended up in the control panel.
  12. #11
    Sep 2015
    I suggest using the IFM
  13. Likes Tech Rob liked this post.
  14. #12
    May 2012
    California
    Just install IFM
  15. Likes Tech Rob liked this post.
  16. #13
    Quote Originally Posted by HYP1278 View Post
    IFM Efector u40100
    I've installed probably 100 of these and have replaced maybe 4 for various failures. They are the most reliable solution out there for fluid flow proving. They are virtually maintenance free.
    The key to happiness is lower expectations.
    Don't pick the fly crap out of the pepper.
    A vote is like a rifle; it's usefulness depends on the character of the user.
  17. #14
    Apr 2021
    Definitely agree with the others on here regarding the IFM Efector.
  18. #15
    Jan 2005
    Houston TX
    I've heard several different options here. I agree that the IFR would be the best. But, dollar for dollar the McDonald / Miller would be the best option. As far as condensation is concerned you can put oil in the body and use duct plug to fill the incoming electrical, never had an issue !
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
  19. #16
    Indiana
    If customer doesn’t want to spend the money a Harwill Q5 is an excellent flow switch, more durable than McDonnell Miller for large applications.
  20. #17
    Tampa
    IFM
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
