+ Reply to Thread
Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 62
Thread: Receiver goes back into cond coil ?
  1. #41
    Aug 2013
    Omaha
    Quote Originally Posted by BobFrost View Post
    On condensing units wothout subcooling circuit there is no check valve.
    Why is here necessary?
    Because those condensing units.. like heatcraft, russell, trenton, etc have actually good low ambient controls like a headmaster or variable speed fans so theres no need for a check valve.
    Unlike a crappy low cost, cheaply designed kolpak unit.
    Sent from my SM-G975U using Tapatalk
  2. Likes VTP99 liked this post.
  3. #42
    Mar 2015
    Medford, N.Y.
    That check valve also prevents migration.
  4. Likes R600a, BALloyd liked this post.
  5. #43
    On a bull named Foo Manchu
    I wonder who figured out the check valve thing. Can they get away with less total charge that way or is it about the same?
  6. #44
    Apr 2008
    Michigan
    Quote Originally Posted by Snapperhead View Post
    Ok .... but why
    Whats the benefit
    They have worked forever without them
    Does it stop the bubbles when the fan kick on and off ? I did notice there werent any bubbles ....
    It's not really a question of them working/not working, they will work fine with or without. It's an efficiency kick. The subcooling circuit, the check valve preventing temporary flashing at the expansion valve, variable speed fans, etc. are all a direct result of the AWEF mandates imposed on the industry in 2020. The cheaper units in particular had to make some efficiency improvements in order to meet the new regulations.
  7. #45
    Mar 2015
    Medford, N.Y.
    I would say this style of x-tra SC'ing cond unit thing needs a little x-tra freon for the slightly x-tra liquid line length.
  8. #46
    Virginia
    Thats just what we need .... more crap that can go bad
  9. Likes R600a liked this post.
  10. #47
    Quote Originally Posted by TechmanTerry View Post
    Maybe it's a wash then. I can't see them adding the check valve with the sole purpose of it running better with the fan cycle.
  11. #48
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Unless that's what it took to get them to break down past warranty instead of in warranty.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  12. #49
    Dec 2014
    Hey Terry!
    Sent from my SM-G950U using Tapatalk
  13. Likes R600a, BALloyd, bacciagalupe liked this post.
  14. #50
    Jan 2010
    I've always added a check valve when adding a HPC valve.
    I believe it's in a Sporlan bulletin as well.
    As for the migration I've never added a heat tape to a condenser but I have on a receiver.
  15. #51
    Apr 2003
    Maple Grove, MN
    Interesting. Thanks for posting that icy78. But why would we care if refrigerant migrates from the "warm receiver to the cold condenser" during the off cycle? I suppose it's so you don't have a few seconds with a flashing sight glass upon startup again? Doesn't seem like a big deal to me. Am I missing anything?
    I'm guessing the scroll compressor has a check valve built into it as well, correct?
    If at First You Don't Succeed, Skydiving Is Not for You.
  16. #52
    Quote Originally Posted by ammoniadog View Post
    They have a hard time starting back up when it cold out.
  17. #53
    Apr 2008
    Michigan
    Can't argue with that!🙂
  18. #54
    Apr 2008
    Michigan
    I may be wrong here but here's what I think they are trying to accomplish.
    We often install outdoor units with heated and insulated recievers around here for extreme cold conditions. Its necessary to keep receiver pressures high enough to come out of pumpdown after long off periods when it's -20F or colder outside. A unit with an HPR or "headmaster" acts as a quasi-check valve since it closes to the condenser when the receiver pressure drops, thus helping prevent (but not necessarily eliminating) migration back into the condenser which would happen readily when its cold outside since the condenser is obviously designed for heat rejection. Since this unit has only fan cycling they may have added it to discourage migration and low head pressure when it comes out of pumpdown. I have seen several of these units however that work just fine in pretty cold weather without the check valve. I think it also serves the purpose of preventing flashing due to the fan cycling as mentioned too.
  19. Likes UmmScott liked this post.
  20. #55
    Apr 2021
    East ohio area
    Would there be a different best practice for charging this unit in regards to this design?
    Not sure if there would be any idiosyncrasies
  21. #56
    Southold, NY
    Quote Originally Posted by Swf View Post
    Normal charging when warm outside but extra refrigerant is needed for the flooded condenser. Its in the IOM.
  22. Likes BobFrost liked this post.
  23. #57
    Mar 2015
    Medford, N.Y.
    The need for a receiver heater is based on 0*F and colder and a few other reasons.
  24. #58
    Apr 2008
    Michigan
    Except it doesn't have an HPR valve?
  25. #59
    Jun 2012
    ICM control will work with that motor.
    Which one do you prefer?
  26. #60
    Nov 2009
    Richmond, working under tarps
    Quote Originally Posted by ttowngremlin View Post
    you should be able to pick the one best for your application
    https://www.icmcontrols.com/products/?category=41
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
