+ Reply to Thread
Results 1 to 20 of 20
Thread: 800lbs of old hvac gone
    Jul 2019
    Montana
    Fun changeout. Customer originally had someone they paid upfront to replace the hvac but the guy took their money and left the units there. So we got hired to put in what he bought! He had an 80% goodman and a bryant ac unit and coil. We ended up putting in a runtru 96% and the bryant equipment. Just waiting for all the electrical to be updated now and then we will start it up
  2. Likes dieseldude, R600a, STEVEusaPA, heatingman liked this post.
  3. #2
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    Lets see...800lb of cooling is....(counting on fingers)....4800btu.
    Sorry I couldn't resist.
    Your install looks good.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  4. Likes mofotech liked this post.
  5. #3
    Oct 2011
    Culver, Oregon (Central OR)
    Looks like you had some cleaning up of wiring still to do, and that gas valve is off, but nice job otherwise.
    Do like I do. Wait until you have the customer's check in hand and all is done. Then it is picture time .
  6. #4
    Jul 2019
    Montana
    Like I said still waiting on the electrician
  7. #5
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by 406Tinner View Post
    You let an electrician touch your unit?!
  8. Likes mofotech liked this post.
  9. #6
    May 2019
    How did the heat exchanger look in that old Lennox unit? 50-60 years old.
    The ones I have seen looked heavy enough that you could almost have burned wood or coal in them. Seldom burn thru walls.
  10. Likes R600a, heatingman liked this post.
  11. #7
    Jul 2019
    Montana
    When they're updating the entire electric for the 1950 house I sure do, new service, new panel, all new romex. Also it's not just some electrician, we do work with the guy all the time
  12. Likes R600a liked this post.
  13. #8
    Jan 2012
    Broomall, PA
    Awesome, as usual.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Helpful Calcs, tips, tricks on my YouTube channel: https://www.youtube.com/channel/UCgm...TUTAdKmqRiTDEg
  14. Likes 406Tinner liked this post.
  15. #9
    Oct 2011
    One thing I like to do in basements and garages is run the secondary drain into a bucket with a little pea gravel in it and install a hockey puck wet switch in it.
  16. #10
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by Adlerberts-Protege View Post
    Just curious why the pea gravel?
  17. #11
    Other than the lack of a media air cleaner, looks good. Bet his gas bill drops like a rock!
  18. Likes 406Tinner liked this post.
  19. #12
    Jun 2012
    Northern NV
    That old Lennox air cleaner cabinet. Did it have the media filters with electronic air cleaner? Have not seen one of these since I worked for a Lennox dealer in the 70's! Was a heck of a filtration system....
    “A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.”
    ― Robert A. Heinlein
  20. #13
    Jul 2019
    Montana
    No it had nothing. In the blower compartment it had some mesh stuff in a u shape under the blower
  21. #14
    Mn the state where absolutey nothing is allowed
    what the hell did you do with the siegler?
    that was a wonderful space heater......
    my boss thinks its possible to repeal the laws of physics
  22. #15
    lennox bulk filter media, came on a 25 foot roll. the reason i carried a scissors on the truck in my early days.
    pain in the rear to use the slides to latch to the "fence" to hold the media in place
  23. #16
    Oct 2009
    Florida
    Referring to the Speigler..
    Was that the short clunky thing on the left?
  24. #17
    Jul 2019
    Montana
    Yes it was! Pretty sure it was heavier than the furnace. When I threw that out if my box van it hit the ground and that was it no roll or anything.
    Unfortunately I collect all the old logos of units I rip out and the speigler broke..
  25. #18
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    I am just guessing but my guess would be that the gravel is there to precent nuisance trips. If the puck is directly on the bottom of the bucket even a drop of water can set it off. Set up an inch or three on pea gravel or marble chips it would only alarm if the overflow got serious.
    PHM
    Quote Originally Posted by R600a View Post
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  26. Likes R600a liked this post.
  27. #19
    Jan 2001
    Pacific Coast of Canada
    Hey sorry to possibly be "that guy" but check local codes regarding an orphaned water heater. Can't really see what the water heater is vented into.
  28. #20
    Chicago area
    Quote Originally Posted by Collin View Post
    Looks to have the flue wrap around behind the furnace into the what looks like 6” b-vent.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
