+ Reply to Thread
Results 21 to 40 of 48
Thread: True Freezer Suction line freezing
  1. #21
    May 2014
    Bay Area California
    I see a big pipe in the photo.
  2. #22
    Nov 2009
    Richmond, working under tarps
    which pic are you referring to?
  3. #23
    Southold, NY
    Quote Originally Posted by indy2000 View Post
    I'll A S S U M E the #18 green.................... what's that a Scroll?
  4. #24
    Nov 2009
    75HP bitzer twin screw
    1 of 4 on a parallel rack driving a spiral blast freezer
  5. Likes pecmsg, VTP99 liked this post.
  6. #25
    Nov 2009
    we call this integral
    oil cooling
  7. #26
    Southold, NY
    I ment screw. Too early in the AM
  8. #27
    Jan 2010
  9. #28
    Jan 2010
    This one ?Name:  Screenshot_20210226-110149.png
  10. Likes mofotech liked this post.
  11. #29
    Nov 2009
    HSN
  12. #30
    Nov 2009
    have a couple of those on ferries
  13. #31
    Nov 2009
    TWIN screw
  14. #32
    May 2014
    Bay Area California
    I can barely perform to a high standard with one screw, can't imagine satisfying a twin screw with that same performance.
  15. Likes indy2000, WT70 liked this post.
  16. #33
    Nov 2009
    dont limit yourself
    expand your imagination!!
  17. Likes BBeerme liked this post.
  18. #34
    Oct 2011
    Harrisburg, NC
    Been so long since I’ve even had to think about performing with 1 screw, two would liable to burn out the main.
    I can't fix it if it won't stay broke..
  19. Likes 2sac, BBeerme liked this post.
  20. #35
    Jul 2020
    Update
    Quote Originally Posted by MMadatic View Post
    Ok Thanks for the help....
    Ran the freezer for 1 full week with no problems. temp of box was between -5 and -10 deg F. I unpluged it and and let it set for about 10 days. Just plugged it back in and the compressor made some unusual noise. It tripped twice and then started to run normally. It seems to be cooling properly. Any Ideas why it would trip at first start up???
  21. #36
    On a bull named Foo Manchu
    9 ounces of charge over the nameplate.
    You have a cro valve?
  22. #37
    What exactly is tripping?
  23. #38
    Southold, NY
    Excessive back pressure. You need a Crankcase Pressure regulator!
  24. #39
    Jul 2020
    The overload protector is tripping. It clicks off for about 5 secs than back on.
  25. #40
    Southold, NY
    Its tripping because the back pressure is to high causing excessive amperage. Its also not doing the start parts any good!
    Whats the max amperage for that pump? You set the CPR valve to limit the back pressure to just below that #!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
