Results 1 to 10 of 10
Thread: Running pipe to fireplace
    Friend of mine wants to install a propane fire log into the existing fireplace
    Whats the proper way to run the pipe ?
    Tank is going right outside the wall
    I assume you just run copper pipe into the crawl then up into the fireplace flooring ?
    Are the propane tank guys going to require a permit before they fill it ?
    Im not a plumber ....
    Aug 2000
    Sacramento, Ca. USA
    You can’t use copper. Follow local codes. The one time I helped we drilled through the chimney into the fireplace. If you have a plumber friend use him.
    If not hire a professional.
    Nate Certified
    Around here there's soft copper running to many Furnaces , so I figured fire logs would be the same
    Jan 2010
    Sea to Sky
    Quote Originally Posted by lrussell View Post
    Says who? See copper all the time. As you mentioned...check your local codes. I realize some jurisdictions don't allow copper but I would say they are the minority in NA.
    Sent from my SM-G965W using Tapatalk
    Aug 2000
    Sacramento, Ca. USA
    Quote Originally Posted by BALloyd View Post
    I’m no plumber as you can tell. My experience is with natural gas. My mistake. Although I still like the idea of using black pipe.
    As I said we drilled through the fireplace from outside the house and penetrated just inside the fireplace. Where you can make up the final connections. It takes a long bit and hammer drill capable of doing the job is all. Same for the copper if that’s what you want to use.
    Nate Certified
    Yeah with Natural Gas all I see is Cast iron pipe
    Im not sure why Propane uses copper pipe
    Jan 2010
    S.E. Pa
    Copper is approved by the gas codes UNLESS you have greater than 0.3 grains of hydrogen sulphide per 100 SCF. Your LP provider will advise you but understand most of the country uses soft copper for LPG. If you want to use steel pipe through the wall, it should be galvanized steel unless too much H2S. Otherwise, you'll have to paint the pipe first. Also, it should be sleeved through the masonry.
    With a DOT LP cylinder right next to the chimney, you can use a combination first and second stage regulator under the bonnet of the tank. It is recommended to have a sediment trap protecting the logset though not required on fireplaces. Put a shutoff inside the firebox for service then a flexible appliance connector to the logset.
    Before you charge off installing gas logs understand you must perform a level II inspection of the chimney per NFPA 211. If it is not suitable for burning wood, it is not suitable for vented logs. If ventfree logs, it still must be intact. The profile gap between the damper frame and facade must be sealed with refractory mortar. Check your clearances to the combustible mantel facing esp. with VF. If vented logs, you will need to remove the damper or block it wide open to maintain the stated "minimum PERMANENT net free opening" stated in the instructions. If you have a remote control, the damper must be left wide open. Otherwise you can close it to the MPNFO but why? You can install glass doors to minimize the cold downdrafts. Fix the house and the cold air till abate. Understand vented logs entrain about 400-600 CFM while burning and a good 100CFM at standby so they are energy losers. VF logs cannot be installed in a lot of areas so do your homework.
    HTH
  9. Likes kangaroogod, BALloyd liked this post.
  10. #9
    Jan 2010
    Hey hearthman I thought it was frowned upon but is galvanized pipe even galvanized on the inside ?
  11. #10
    S.E. Pa
    It's actually required around Philly by PECO for exterior piping because their gas is scrubbed. Gotta' check with the utility. Zinc sulphide flakes can clog a valve just as copper sulphide black flakes can. That's why I incorporate a sediment trap in all my installs even though not required.
  12. Likes VTP99, lrussell, pecmsg liked this post.
