+ Reply to Thread
Results 1 to 20 of 39
Thread: Anyone buy it yet ?
    Jan 2010
    Anyone buy it yet ?
    Personally I just sand the shaft never have a problem.
  2. Likes CEAS-AC-TECH liked this post.
  3. #2
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    I just use a hack saw and a mill bastard file. They are handy for many other things also so the space in my truck is better used for them.
    Sent from the Okie state usin Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  4. #3
    Mar 2016
    Dayton Oh
    Why not just a fan puller.....
    Plumbers sand cloth, spray lub/ rust buster and fan puller.
  5. #4
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by jbhenergy View Post
    Oh is that what its for? I thought it was for trimming shafts to length.
  6. #5
    Northern Calif
    I’ve had about 5 condenser fans over several years, that were rust-welded on, broke one puller and jacked up the fan blade. If I was still doing residential I would get one.
    I'm not young enough, to know everything...
  7. Likes CEAS-AC-TECH liked this post.
  8. #6
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    What happens if there is no shaft stub sticking out through the hub?
    PHM
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  9. Likes WT70 liked this post.
  10. #7
    Jan 2010
    PHM
    That Gizmo flops around in the blower wheel 😆
  11. Likes dieseldude liked this post.
  12. #8
    R600a's Avatar
    Jul 2019
    I still fail to se the purpose. Now that I know it isn't just for cutting shafts to length I can't figure out a use for it. Is it obvious and I just had too much bourbon tonight?
  13. Likes JayMan7 liked this post.
  14. #9
    Northern Calif
    Quote Originally Posted by R600a View Post
    typically the end of the shaft sticking out of the hub is the most rusted area, this cut off tool cuts the shaft almost flush with the blower hub.
  15. Likes VTP99 liked this post.
  16. #10
    R600a's Avatar
    Jul 2019
    Quote Originally Posted by dieseldude View Post
    Oh and that is supposed to make a big difference? The really stuck ones I have seen were stuck firmly in place. They didn't have a chance of sliding onto the rest of the rusty shaft.
  17. Likes JayMan7 liked this post.
  18. #11
    Northern Calif
    with the cut shaft , it is easier to mount the fan puller or drive the shaft out with a hammer and drift punch..
  19. Likes VTP99, R600a liked this post.
  20. #12
    Jan 2010
    Like the guy who didn't think he needed to land the setscrew on the flat 😆
  21. #13
    R600a's Avatar
    Jul 2019
    Exactly or the old fans that had two set screws and never want to come off.
  22. #14
    Jan 2010
    Two setscrews one flat 🤔
  23. #15
    Feb 2013
    Sonora, California, United States
    And a hammer....
    I always smack it down to break free before trying to get it off...
    I've never found one I couldn't get off. Might take 30 minutes but so far they have always came off. A few have required torches....
    Sent from my SM-G998U using Tapatalk
    "This Story Is True, Only The Facts Were Changed"
    "It's Not Black vs White, Left vs Right, Mask vs No Mask! Its Us vs Them! Stop Letting Them Divide Us And Take Our Control!"
    "Is This Your Opinion Or Experience?"
  24. #16
    R600a's Avatar
    Jul 2019
    Yep. I think it was carrier or something.
  25. #17
    Jan 2010
    I've seen them as well and shafts with two flat sides.
    Might be a case where going oem is advantageous.
  26. #18
    Northern Calif
    Lennox..
  27. Likes R600a, joemach liked this post.
  28. #19
    R600a's Avatar
    Jul 2019
    Once some hack changes that motor and cranks both screws down it might as well be a single part.
  29. #20
    May 2018
    Have you seen the companion product, the supco motor shaft cleaner? For $60, I'll use sandpaper for whatever.
    https://mccombssupply.com/supco-psc1...B#&gid=1&pid=1
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
