Results 1 to 20 of 20
Thread: Niagara WebLauncher
    Apr 2014
    Niagara WebLauncher
    Hi all,
    Upgraded an AX station to N4.8 Am try to connect with the customers windows 10 computer. Get the screen for entering the URL, then get to the login. After logging in get to the loading page but status bar at the bottom disappears after about a minute and says loading module list but never goes any further.
    TIA for any help
    May 2009
    SC
    You get that in the browser or in niagara web launcher?
    Using workbench can you open the station on the same network the customers computer is on?
    Add a HX user profile login and try that in the browser.
    Kenilworth NJ
    My mind is telling me web launcher went away about a year ago....
    Hmmmm....smells like numbatwo to me.
    May 2009
    SC
    Really? I just set one up last week on a 4.9 jace. Is it considered legacy or something? It was the first thing I found that gets you wire sheets without full workbench.
    Jan 2003
    Think the old web launcher died with the java licensing change. The new launcher, whatever they call it, still works in current N4 releases. Not sure if they updated AX for this. If so, I'm guessing its only the latest 3.8.5 something release.
    Jul 2009
    Wa
    Yeah Java webstart went away awhile back. Niagara web launcher works I've used it a lot. Haven't seen the issue markgHvac is describing.
    Jan 2003
    Quote Originally Posted by Norriski Tech View Post
    I have and its the old skool web launcher.
    Niagara launcher works. On the logon screen the wording changed from web to niagara launcher. Not sure this launcher made it to AX and if so, its only going to be in the most recent releases. N4.6 and below also use the old skool launcher off memory.
    Jul 2009
    Wa
    Quote Originally Posted by orion242 View Post
    Hmm? Old school= Java webstart stopped working when Oracle killed support around 1.9jre New school= Niagara Launcher or web launcher? Works fine in 4.8. Was there something between webstart and the launcher? I don't recall that ? Are you saying he's using old school?
    Jan 2003
    The old web launcher does exactly what they describe. You get the login prompt but it craps the bed after that. The wording changed on the logon screen and that's the easy tell.
    Jul 2009
    Wa
    Sorry little slow here! Your point is look at the wording to determine if your using the wrong one. I know it says something different, but setting it up is also different that would be the tell to me.
    Kenilworth NJ
    Ah webstart vs weblauncher. Yes webstart died. And if you try to use it, it does give the error described if you try and you got newer Java installed if memory serves.
    May 2009
    SC
    The current thing is indeed "Niagara Web Launcher"
    Executable installers for the client app:
    64-bit systems: https://weblauncher.niagara-central....ebLauncher.msi
    32-bit (-x86) systems: https://weblauncher.niagara-central....uncher-x86.msi
    You can generally get those straight from the jace too, I think.
    What you also get from the jace by clicking on the web launch link on the web page is a (stationname).nwl file. This is a simple text file containing your jace IP address;
    host=https://192.168.2.140
    Basically it's just a clickable shortcut you can save on the desktop. If you don't have one you can make your own with notepad.
    San Diego, CA
    Quote Originally Posted by markgHVAC View Post
    Hi all,
    TIA for any help
    Niagara Web Launcher 20.1.3 is a major upgrade from the prior version. It carries a number of bug fixes and internal library upgrades to bring it into parity with Niagara release version 4.9 and up.
  14. #14
    Jul 2002
    I have an install by another company at 3.7. I put "Niagara Web Launcher" on the customer's computer but it wouldn't work with that version I guess. What level must the jace be at? I'm trying not to incur any cost, license, or driver changes. (I'm afraid I'll brick it). I walked through the 3.8.311 commissioning and didn't see any module titled Webstart. Is it just in the upgrade somewhere and not separate?
  15. #15
    Jan 2003
    Quote Originally Posted by incontrol View Post
    Pretty sure its part of the web.jar.
  16. #16
    Jul 2009
    Wa
    Want to say 3.8.213 some where in that rev? Have used it a bunch on 3.8 stations so think you've got no choice but to go up.
  17. #17
    Jan 2003
    https://www.jacksoncontrol.com/techn...e-for-download
    AX 3.8u4 and higher from the looks of it.
  18. #18
    Jul 2002
    Someone mentioned 3.7.108. Is it available in that so I won't need a license change?
  19. #19
    Kenilworth NJ
    I remember it being 3.8.113... I know it was not in 3.8.38 or the one after (83?)
    I do not think it was on 3.7 at all... but I am wrong plenty of times. The way to know is to upgrade it to the latest 3.7 and see how it goes.
  20. #20
    Jan 2003
    Ditto pull a backup and launch it on your laptop to see.
