Results 1 to 8 of 8
Thread: Furnaces water broke
    Oct 2014
    Saint Pail, Minnesota
    End of a long cold day here in Minnesota when I arrived to this customer. Customer is a small Muslim grocery. Pressure switch fault was the issue. Checked everything in the furnace and checked terminations outside, the. I heard gurgling.
    Return back to the dungeon of a basement to find random joints on the exhaust leaking.
    Found where the pipe was trapping condensate. I cut the strap and had what seemed like gallons falling from every leak point.
    I investigated the tape thinking it was just covering up a whole from a combustion analysis originally. Nope, the tape was a coupling. I also was able to pull apart 3 other joints that were not primed or glued. Also note on the 2” there is high temp silicone.
    After a trip to Home Depot for materials I polished a turd with new exhaust pipe nears the furnace.
Size:  109.7 KBName:  D9FBAB0A-E55C-42AC-86E6-2E723D14E47A.jpeg
Size:  94.4 KBName:  A1525347-E8D1-4E0D-AC9B-D260CEEE07F1.jpeg
Size:  59.5 KBName:  5C92B4BB-FC3F-4B2F-B6B4-6E7BF2B2944B.jpeg
    Northern Calif
    Is that your pressure gauge in the unit?
    I'm not young enough, to know everything...
    Oct 2014
    Quote Originally Posted by dieseldude View Post
    Inside the furnace yeah that’s my magnehelic. Which that is another issue I found only 3” going to the furnace when it’s running.
    May 2020
    Haskell Oklahoma
    I truly believe people are so stupid and they think that since it’s not a pressure pipe it doesn’t have to be glued. I find em just stuck together all the time.
    Jan 2010
    Is there a union inside the furnace ?
    Oct 2014
    Yes there is.
    Athens, Ohio
    The good old "foil tape coupling." I've found them too often to be surprised any more.
    Site member map HERE!
    Oct 2014
    Quote Originally Posted by kdean1 View Post
    Yeah I’ve never seen it around these parts. I think this thing was in someone’s garage and then he hooked it up for this customer. There was still scrap sheet metal and some scrap csst lying on the floor.
