Page 1 of 4 1234 LastLast
Results 1 to 20 of 74
Thread: Reversing valve wiring issue
    Jan 2021
    Florida
    Have a bosch condenser heat pump which the reverse terminal energizes for heat mode, the air handler however is made by trane which the terminal O is energized for cooling. Thought Rheem was the only one that was backwards but seems the new Bosch units are wired this way too. Whats the best way to approach the wiring issue?
    Jul 2011
    DFW, TX.
    Programmable t stat.
    Sent from my LM-G820 using Tapatalk
    Mar 2018
    Kansas Flatlands
    Quote Originally Posted by CEAS-AC-TECH View Post
    Nothing energizes in the air handler with an O or B terminal, the best way to approach it is match the AH and HP. Many issues may come with an unmatched HP and coil in the heat mode.
    Jul 2011
    DFW, TX.
    Quote Originally Posted by theoldscroll View Post
    Agreed. I was saying he could use a programmable t stat and energize said out put to the units needs. Connected to the condenser of course.
    Thinking about it hey o.p. how long you been doing HVAC?
    Jan 2010
  6. Likes CEAS-AC-TECH liked this post.
  7. #6
    Southold, NY
    Well if you want to get real technical
  8. #7
    Aug 2009
    Beatrice, NE
    The O terminal on the air handler is just that a dead terminal, a place to land wire(s). The only power on that terminal is what is put on it through the wires. The answer to the question you are asking is in the thermostat. if you don't understand then you need more education to be working on this kind of equipment.
  9. Likes CEAS-AC-TECH, BALloyd liked this post.
  10. #8
    Apr 2006
    Tyler, Tx
    Actually some Tranes will use the "O" to set the blower speed, if using an ECM. "O" will also be used to determine if the EEV is in cool mode or heat mode. Your answer depends on which Trane Air Handler you have.
    Philippians 4:13
    I can do all things in him that strengthen me.
    Apostle Paul inspired by GOD.
  11. Likes ksefan liked this post.
  12. #9
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by Artietech View Post
    That is mainly on the 2 stg scroll compressor units, air handler does not matter.
  13. #10
    Jan 2021
    Florida
    Thats what I have. Ecm with variable speed. So im guessing two options then. Set it to full speed or wire in a custom relay to energize/denergized the airhandler oppisite the condesner.
  14. #11
    Jan 2010
    How about some model numbers ?
  15. #12
    Jan 2021
    Florida
    Bosch bova36hdn1m20g
    Trane tem6a0b30h21saa
  16. #13
    Jul 2009
    South Carolina
    Assuming this is not a communicating system, why not just leave the existing T-stat that activates the RV in cool & put a simple SPST relay at the outdoor unit.
    I've done that plenty of times with Rheem/Ruud hp units. Before 410A we used to change tons of just outdoor HP's on the ocean front & leave the old AH.
    Gary
    http://www.oceanhvac.com
    The best things in life are free but not everyone is willing to pay the price.
  17. #14
    Aug 2009
    Beatrice, NE
    Why not just put on a good thermostat that you can choose whether to energize the RV in heat or cool.
  18. Likes R600a, Unlimited1, CEAS-AC-TECH liked this post.
  19. #15
    Jan 2021
    Florida
    Quote Originally Posted by BNME8EZ View Post
    Because a good thermostat can only energize heat or cool not both on two seperate terminals.
    Ah ecu needs energized for cooling
    Rv needs energized for heat
    Im going to try the relay idea. Just was a little gun shy but now that I know its been before i will try it out. Thanks for the help. Will let you know how it turns out
  20. #16
    Southold, NY
    Quote Originally Posted by brainsboy View Post
    W
    T
    F
    A good T stat will decide when and how to energy!
  21. Likes lions_lair, Unlimited1, CEAS-AC-TECH liked this post.
  22. #17
    Jan 2021
    Florida
    W
    T
    F
    Wtf??? Did you even read the original post? Tell me how a good tstat will fix this? A good programmable tstat gives two choices energize in heat or cooling right?
  23. #18
    Southold, NY
    WTF
    A good t-stat allowed you to decide if O or B is energized in cooling.
  24. Likes CEAS-AC-TECH liked this post.
  25. #19
    Jan 2021
    Florida
    Yes then what? The air handler needs energized for cooling but the condsenser needs non energized for cooling get it now???
    Ah for cooling needs O energized.. then for heat not energized
    Condenser for cooling O is not energized, heat is energized
    Rheem and bosch work backwards from everyone else.
  26. #20
    Aug 2009
    Beatrice, NE
    You do realize that the air handler doesn’t care if the RV is energized or not.
  27. Likes lions_lair, Unlimited1, CEAS-AC-TECH liked this post.
