Results 1 to 7 of 7
Thread: Multimeter errors
    Jan 2021
    Multimeter errors
    I just bought a Southwire clamp meter at a pawn shop for 25 bucks. Only thing I don't like about it is that the red lead shows voltage even when the black lead is still open (not touching anything). What could cause this? Can it be fixed? There were no fuses when I opened it up.
    Sent from my LG-US998 using Tapatalk
    Jul 2005
    Quote Originally Posted by Abbasis View Post
    That’s normal
    Nov 2020
    But I can't feel it's normal if I happen to observe this.
    Aug 2020
    Seattle, WA
    Floating leads will pick up stray voltage from all sorts of places, particularly from 60Hz AC all around you. Many multimeters have a 60Hz filter that drops most of it, but that one might not. As long as the voltage goes to zero when you short the leads, and you've tested it on a known voltage, I wouldn't worry about it.
  5. Likes dieseldude liked this post.
  6. #5
    On a bull named Foo Manchu
    If it bothers you can you change the range higher so you don't see the mA bouncing around?
  7. #6
    Jul 2005
    Quote Originally Posted by JoeyMarquez View Post
    Don’t connect only one lead, and your problem will be solved.
  8. #7
    May 2009
    And there in lies a relatively common issue with some digital multimeters. Incorrect readings because the operator fails to read the display properly. Mv Millivolts.....V Volts......Ma Milliapms.....A Amps, and so on. If you are aware of this characteristic, it's a non- issue.
    In general, higher quality digital meters are more sensitive, and their readouts will have a tendency to float somewhat with their leads disconnected.
    In addition, in certain conditions, digital meters can also have a tendency to dampen their readouts, or sometimes be influenced by high electromagnetic fields such as those present in some frequency drives.
    Just a couple reasons to carry a higher quality back up analog dinosaur meter.
