Results 1 to 1 of 1
Thread: sparkly
    in a house, Appomattox, Va.
    sparkly
    wasn't even here to look at electric, saw lights flickering and investigated. (shorted wire in heat pump, no heat call). neutral lug and wire had come loose from bar in disconnect. current was trying to run back to meter and transformer through the offset fitting, which was a bit loose.
    got auth from power co to pull meter and fix neutral lug.
    Col 3:23
