Results 1 to 7 of 7
Thread: SMARDT CHILLER OIL FREE CENTRIFUGAL CONTROL
    Dec 2020
    good afternoon.
    refrigeration mechanics.
    I have a problem, and I need help.
    Putting it in context, it is the December holiday season, I am in a tropical coastal area, it is when the greatest refrigeration load is needed.
    I have two SMARDT OIL FREE chilled water generating units, each with 2 turbocor tt400 compressors.
    I only have one computer working, the other damaged the kiltech control cpu, the unit was already bought, it comes from Canada, because of the distance and customs, I think it will be late. I've been trying to start the computer manually.
    The equipment in operation has an axiomtek 201 cpu with 4 ports for communications, 2 of them used for kiltech control and compressors.
    Some of you will know if the module will support connecting 2 more communications, in this case it would be the other unit.
    I have installed fast action to clone the system and adapt it to a personal cpu, we continue in the attempt.
    I do not have access to access code.
    If you can help me I would be very grateful.
    Greetings colleagues from the refrigeration and air conditioning
    The Hot South
    Do you have Gen 3 or 4 controls. In either case you need to get that controller or retrofit to another controller.
    The 2nd most important amendment is to protect the 1st....
    Free Air Conditioner Sizing Chart
  3. Likes FRIAS liked this post.
  4. #3
    Dec 2020
    It is generation IV, after many tests and attempts I managed to keep the 2 chillers on, one in standard mode and the other using the killtech cpu. monitoring compressors with danfoss application for compressors. I do not have the access code and it is programmed to only 40% of maximum demand.
  5. #4
    The Hot South
    Is it the Windows computer that went bad or the actual chiller controller
  6. #5
    Dec 2020
    the kiltech cpu, the one with the 4 communication ports, the main system memory was damaged, rbox 201 4com . Axiomtek
  7. #6
    Mar 2015
    I'm wondering the same thing. Just an FYI, there is a fuse on the Kiltech right where the 24VDC power supply plugs in.
  8. #7
    Jun 2007
    OK
    I have the same chillers
    try code 1234 or 4321
    That should allow you to change the demand limiting
