You need to apply for pro status to get that sort of help here .
I can't remember how to do that but if you go to the homepage it's on there I'm pretty sure.
Sent from my SM-G950U using Tapatalk
How to Bind The Evaporator Water flow switch
also does anybody has the originals manual for this unit
ok thank you
click on bind.... a window will open asking you to identify the item you want to bind with a magnet....light the led with the magnet....and click bind
that should do it
that is the way it works with everything else.....we do not bind flow switches on the centrifugal chillers ….if the switch you have is a llid or has some sort of interface like the drive does you either hit it with the magnet or find a button that will pole it
maybe someone that does recip work will know about binding flow switch on that unit for sure
Don't have to bind the flow switch.Just replace
A couple of screen shots would be interesting.
