Results 1 to 13 of 13
Thread: Air don't care
    Jul 2019
    Montana
    Air don't care
    155k btu 5 ton furnace
    Oct 2011
    Culver, Oregon (Central OR)
    Ya, I see that crap all the time. At least it wasn't an "N" coil .
    Nov 2008
    Piney Flats, Tn.
    what year was that evaporator? It has been a good while since i have seen a cap tube coil.
    Sep 2009
    Marietta, GA
    Whoa..and that sh*t worked fine?
    Nov 2020
    Planet Earth
    Is that working to the desired levels ? I can see a lot of rust in some of the areas..
    Jan 2012
    Missouri, USA
    Was TESP over 2iwc?
  7. Likes Snapperhead liked this post.
  8. #7
    Apr 2006
    Tyler, Tx
    What's the problem? The coil is clean.......
    Philippians 4:13
    I can do all things in him that strengthen me.
    Apostle Paul inspired by GOD.
  9. #8
    Apr 2004
    Minnesnowta
    @DOGBOY I think you're seeing distributor lines, not cap tube. The plastic condensate pan tells me the coil isn't too old.
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
  10. #9
    Chicago area
    The problem probably isn’t the coil. That is probably sized right - perhaps by mistake.
    The problem is likely the furnace. From the looks of it, he could heat the whole neighborhood with that thing.
  11. #10
    Chicago area
    My bigger question is whats up with the gas line?
    Looks like it converts to flex and is shoved into the return duct.
  12. #11
    Jul 2019
    Montana
    Quote Originally Posted by heatingman View Post
    Gas is disconnected, was in the middle of swapping the unit out, saw how they mounted the coil and took the picture then
  13. #12
    Nov 2008
    Piney Flats, Tn.
    Quote Originally Posted by doc havoc View Post
    dude where is the piston or TXV? that is a capillary tube metering device. The big thing that the capillary's come out of is a manifold and has little BB's in it as a drier to keep moisture out of the capillary tubes. That is older than 1992.
  14. Likes heatingman, 406Tinner liked this post.
  15. #13
    Mar 2018
    Cottonwood, Ca #StateofJefferson
    It's more monster than machine
