+ Reply to Thread
Results 1 to 13 of 13
Thread: Smallish Hot water boiler just wrapped up this AM
    Chicago area
    All work was in house, no outside vendors used. Still need replace the OA damper and louvers.
    Before
    Sent from my SM-G930V using Tapatalk
    Chicago area
    After. Gonna clean up the wiring in the control enclosure after the OA damper is replaced, as a little more wiring needs to be done to interlock the OA damper once its installed
    Northern Calif
    Nice Job.. is the Honeywell control for the three way?
    I'm not young enough, to know everything...
    Chicago area
    Yes the T775 is for the 3 way valve.
    The Heat timer controls the boiler reset via OA both start stop, and the modulation signal to the burner and also the main system pump.
    The T775 controls the 3-way on its own reset schedule via OA temp and supply temp to the building.
    The boiler reset is higher temp, 145 low end and 185 high end.
    3 way does 130 low end to 180 high end. And is programmed for a minimum output of 20 percent to never totally loose flow through the boiler.
    Id prefer a single control for both functions, but that requires me to take the time to custom program something more DDC based, which I reserve for more complex systems. And also, more people can work on these controls, while the custom stuff marries me to it forever.
    Also, the heat timer comes with the burner from our vendor, so may as well use it.
  5. Likes dieseldude, GoCougs, icy78 liked this post.
  6. #5
    Nov 2014
    OR
    Very nice, thanks for taking the time to post that.
  7. Likes heatingman liked this post.
  8. #6
    Nov 2014
    OR
    Heatingman did you install the conduit yourself or did you have an electrician run the pipe?
    If so nice job, I really like the appearance of EMT for anything more than short whips.
  9. Likes heatingman liked this post.
  10. #7
    Chicago area
    I ran the conduit myself. On a smaller project like this, thats generally how we do it.
    A bigger job, not necessarily bigger equipment, we will pull in electricians.
  11. Likes GoCougs liked this post.
  12. #8
    Oct 2014
    Maplewood, Minnesota
    Are you an in house guy? What sort of place was this installed at?
  13. #9
    Chicago area
    Im a pipefitter, on the service side. I work for a mechanical contractor. By in-house I meant we did not sub anything out to the sheetmetal guys, or electricians.
    Its in a decent sized apartment building.
  14. #10
    Jan 2021
    Nice work Heatingman Bill Wren still at Mokena ?
  15. #11
    Chicago area
    Quote Originally Posted by nantucket View Post
    Not certain, but I think so.
  16. #12
    How many BTUs ?
  17. #13
    Chicago area
    How many BTUs ?
    I don’t recall OTOH
    But it’s somewhere in the 1500 to 5000 MBH range.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
