+ Reply to Thread
Thread: LOG PLACEMENT VERY CRITICAL
    Sep 2003
    Portland.OR
    So I got a used free standing fireplace.. Columbia Bay model
    wouldnt stay light-- THERMOCOUPLE AND THERMOPILE OK /CLEANED ORIFICE /REMOVED CORRISION ON THERMOPILE..
    perfect operation AFTER PULLING THE BACK LOG OVER THE THERMOCOUPLE TO KEEP THE WIND OFF AND BLOWING THE FLAME
    OFF THE t COUPLE!!
    iM REALLY A FURNACE GUY.. SO IT THIS COMMON TO HAVE THE PILOTS HIDDEN?? jUST 1/4 INCH GAVE NORMAL OPERATION
    THANKS fixitguy in portland..
    SE Ohio
    Position of the logs is critical. Incorrect position can cause flame impingement and generate soot. It can cause other issues, too. Since your fireplace is used, I suggest finding the manufacturer's literature and verify the log positions.
    Jan 2010
    Sea to Sky
    Quote Originally Posted by kdean1 View Post
    In addition to the impingement possibly creating high levels of Carbon Monoxide....
    Sent from my SM-G965W using Tapatalk
  4. Likes safebustr liked this post.
  5. #4
    Sep 2015
    Ontari-ari-ari-o
    Improper log placement can also cause the burner to overheat and crack and deform. If the pilot is blowing out you may need to take a look at the venting it might need a wind cap or it could be as simple as just adjusting the pilot a bit.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
