Results 1 to 20 of 35
Thread: Added AC to existing heater. AC wont turn off automatic
    Oct 2020
    I have a very strange issue with the AC we added to existing heater. If we run the AC to test and turn off in couple of minutes, it shuts off.
    But if on a hot day I keep the AC running for longer duration, it would not turn off when temperature is reached or even if I manually turn the sytem off.
    Then I did another test.
    When I run the heater, turns off as expected no problem.
    I did a test as below -
    1>Turn on AC to cool to 65 degrees
    2>It runs for 30 mins or so and keeps going even when temp reaches 65.
    3>I increase the threshold to 67, AC keeps running
    4>I then switched the system to Heat mode. Heater turns on, the compressor keeps running.
    5>In few minutes, I changed the mode to 'Off'. expecting the whole system to turn off.
    6>The heater turns off, but the AC keeps running.
    I have tried 3 different thermostats. The installation tech says there is nothing wrong in the system itself. And I am at a loss. Hopefully someone here has ideas I can try.
    Thanks so much!
    Call your dealer back and have him see what's up. Should have a warranty.
    Oct 2020
    Thanks BaldLoonie,
    The installer tech has come by few times but other than thinking that it is the thermostat to blame, he hasnt found anything yet.. which is where I am looking for ideas here.
    Athens, Ohio
    Site rules prohibit giving technical advice to non-professionals. We won’t be able to help you.
    It seems your installation company is inadequate. You need to find a more skilled technician.
    Site member map HERE!
    Quote Originally Posted by mansat View Post
    Thanks BaldLoonie,
    The installer tech has come by few times but other than thinking that it is the thermostat to blame, he hasn’t found anything yet.. which is where I am looking for ideas here.
    Call the company again. And tell them you want a better tech sent out. One that has a better knowledge of control wiring.
    Cincinnati, Oh
    Could be running in dehum overcool.
    What's the thermostat?
    Southold, NY
    The one MARK loved so much?
    Oct 2020
    I have tested Nest, Honeywell and a Carrier thermostat. All have same results.
    Thanks!
    Oct 2020
    It could be. How can I tell? I do not see any setting or configuration on thermostat to adjust this feature.
    Oct 2020
    The tech now says that he control board is bad. And needs to be replaced! Another $$.
    Southold, NY
    Keep guessing or find a different more qualified tech!
    What board? A furnace's control board doesn't control the central A/C. Unless its an integral part of the furnace.
    Now would be a good time to post brand and model number of both the furnace and A/C.
  14. #14
    Oct 2020
    Interesting. Furnace and heater I have from before is Bryant. And AC is American Standard. Hopefully one of the two images from the board will help determine model.Name:  IMG_0045.jpg
Size:  680.8 KBName:  IMG_0042.jpg
  15. #15
    No, the same board is used in different models. The model number for the furnace will be inside the compartment that has the burners. The A/C model number will be on the outside unit.
    Also, a pic of the thermostat wires connected to the board can help.
  16. #16
    Jun 2014
    Dover, DE
    This seems like a classic symptom of a deranged Nest.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
  17. Likes kdean1 liked this post.
  18. #17
    Oct 2020
    Here are some more pics. Model number and wiring etc. Name:  IMG_0046.jpg
Size:  387.1 KBName:  IMG_0047.jpg
Size:  1.10 MBName:  IMG_0049.jpg
Size:  537.8 KBName:  IMG_0050.jpg
  19. #18
    That board doesn't control the A/C, so it isn't causing the A/C to not shut off.
  20. #19
    Jun 2014
    Dover, DE
    Do you have a handyman or home warranty working on this unit? Or is this a DIY repair?
    As this tech you speak of seems very much confused.
  21. #20
    Oct 2020
    Thanks for the response. Do you have recommendation for next steps?
Tags for this Thread
