+ Reply to Thread
Results 21 to 30 of 30
Thread: Need advice on heaters
  1. #21
    is anyone here familiar with an architecture in Europe referred to as Passvhaus where the primary Heating source is referred to as the construction material , then geothermal heatpump and usually combined with solar, Very well insualted home and some incite to components as well to retain heat. I have one place with it a house where the geothermal feeds underfloor manifolds for each zone , I have been there when down in the 40sf outside and people inside none the wiser heat is made in cylinder but not even being used yet, which is almost unheard of in normal house construction. obviously high first cost investment, but rapid payback in energy savings , this system also makes the DHW.
    Keep it simple to keep it cool!
  2. #22
  3. #23
    May 2009
    Quote Originally Posted by stanbyyourword View Post
    Nothing new, and basically another name, with a couple more whistles, placed on an old concept that's been around for literally decades. They might use solar orientation, radiant mass heat storage, passive ventilation, or a hundred other similar concepts too numerous to list here.
    Check out the underground, and berm home craze from the 60's, 70's, and 80's. Granted, there are some pro's, but there are some very serious con's to consider, before anyone would want to jump on this wagon.
  4. #24
    From what I understand the components down to the tiles are selected specially to retain heat
  5. #25
    Jun 2012
    Northern NV
    This book was written many years ago by a fellow that was building one in Missoula MT and needed no aux heat or cooling. Some of the ventilation ideas were quite genius. Would have liked to build on myself! Just never had the opportunity or the spare cash to do so....
    https://www.amazon.com/Passive-annua...s%2C232&sr=8-3
    “A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.”
    ― Robert A. Heinlein
  6. #26
    Nov 2020
    I think Duraflame is much more beter than the other one. so If I was you, I would select a model from Duraflame
  7. #27
    SE Ohio
    Quote Originally Posted by Unlimited1 View Post
    I wear wool blend thermals and hat with a Columbia Omni Heat reflective gear. I’m mainly sweating my arse off when moving around at a-20 wind chill..
    https://www.columbia.com/c/technolog...eatreflective/
    The jackets look nice. Is there a work jacket?
    How often do you have -20 wind chill in North Carolina? I didn't expect it to be that cold there.
  8. #28
    Apr 2020
    Garner NC
    Quote Originally Posted by kdean1 View Post
    Don’t know about a specific work jacket but I use mine as such when it’s that cold...
    I was in Boone NC that day in the mountains, it gets very cold...In the mountains of VA as well..
  9. #29
    May 2019
    I just found in our local museum a pair of (I believe) pilot gloves.
    They are long cuffed such as welding gloves of today.
    Dug out some items for school kids in house veteran's day program.
    They are very thin leather with liner. There are 2 large snaps at the cuff of each glove.
    Tag inside states 24 volt. The pilot would snap in the leads from the plane power supply.
    Not sure of the age, thinking gloves for B-17 pilots (WW 2) as that plane had no heaters and flew up where temps was 30-50 below zero, IIRC. Not pressurized either.
    The next generation of B-29's was heated and pressurized. Again IIRC.
    Also included my Induction Notice of 1970 and various draft cards......most likely no one will receive these any more. No adults in the high school system have ever seen them either.
  10. #30
    Nov 2020
    United States
    I think you should keep it. In the future, you won't see like that thing.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
