+ Reply to Thread
Thread: Condensation Drainage Problem
    Aug 2020
    Question Condensation Drainage Problem
    Hi.
    My home has 2 HVAC's with coils from Allstyle Coil Company, model FMSP. One one of the units, the bottom pan keeps filling up, stopping the unit. Obviously, it is not draining properly. The draining pipe on both units are connected to the same drain PVC pipe. I've attached some photos.
    Any suggestions on correcting the problem greatly appreciated.
    Apr 2020
    va
    The lower pan & switch is a back-up in case the coil pan or top drain plugs...
    Aug 2020
    Well, yes. I understand that. The top drain, as you called it, is obviously not draining properly. Hence it’s likely backed up. I guess I need to take apart the pvc assembly to find the clog. I was just wondering if there is an easier way.
    Thanks for your suggestion.
    New Jersey
    If you remove the coil access cover, you can try to use a shop vac to suck the clog out of the trap and pipe.
    Sent from my ASUS_P00J using Tapatalk
    Jun 2021
    Having same issues need advice for someone specialist
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
Tags for this Thread
  • You may post new threads
  • You may post replies
