Results 21 to 31 of 31
Thread: Previous tech said everything is fine
  1. #21
    TXV forced full open - charge to target SSH - what could go wrong? <g>
    Hell; I know an AC tech in Florida who says about TXV's - "wool; ah jus let 'er swang baby'.
    "Takes all kinds" has maybe never been more true, eh? <g>
    PHM
    Quote Originally Posted by AIRCON8 View Post
    Attachment 817925Attachment 817925
    But system not cooling well.
    PHM
    The conventional view serves to protect us from the painful job of Thinking
  2. #22
    May 2011
    romulus, mi
    Quote Originally Posted by kdean1 View Post
    Plenty of thermal conductivity with a cable tie, too!
    I've seen them factory shipped using zip ties
    Sent from my GM1915 using Tapatalk
    RTB Mechanical
    734-315-0064
    http://rtbmechanical.com
  3. #23
    May 2018
    FLORIDA
    This one was among the really bad i ever found
    Visit our website at www.airconcomfortcooling.com
  4. #24
    i could see doing this as a temp fix but do it the right way afterwards
  5. #25
    Oct 2014
    Just add “a pound or two” and it’ll be fine.
    Freezon fixes everything
  6. Likes R600a liked this post.
  7. #26
    May 2018
    FLORIDA
    Quote Originally Posted by UrAverageAguy View Post
    No need for a txv in this case LOL
  8. #27
    Houston TX
    You guys have mo idea what you are looking at; that is a sub-cooling modulation valve sensing bulb, so it has to be on the liquid line.
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
  9. #28
    I repaired a comfort cooling job where they were replacing 500 ton screw compressors every few years. All DX coils stacked in gigantic plenums. I guess the coils were 40-50 tons each - with a single TXV on each coil.
    All day the system ran fine, and all summer it ran fine - spring and fall mornings it would slug liquid so bad the screw sounded like it was going to stall the 500HP drive motor. Nobody could figure it out and what the hell; who doesn't like selling 500 ton compressors. <g> Willard Mechanical out of Philadelphia had had the contract for many years.
    Turned out that the original installation fitters had attached all the TXV bulbs with perforated strap iron. When the straps rusted off - the TXV bulbs had dropped down into the condensate pans. So on a dry startup the TXV's were wide open on return air temp. As soon as the coils started working and filled the drain pans with condensate - the bulbs started sensing the water instead of the return air and the SSH came right into line.
    <g>
    PHM
  10. Likes R600a, CHAINIK liked this post.
  11. #29
    Oct 2014
    Saint Pail, Minnesota
    I’m more of a fan of using blue painters tape. I know a guy that works for Sherwin Williams. Way cheaper than traditional straps.
  12. Likes R600a liked this post.
  13. #30
    Feb 2018
    Bay Area, Ca
    Who needs insulation either. Ambient works just fine. Especially in attics.
    Sent from my SM-N960U using Tapatalk
  14. #31
    May 2011
    romulus, mi
    Quote Originally Posted by Zamoramax View Post
    Fk that installation everytime I need it can't find it but a new roll and find all the missing rolls that shit is evil
    RTB Mechanical
    734-315-0064
