Results 1 to 20 of 31
Thread: Previous tech said everything is fine
    May 2018
    FLORIDA
Size:  437.5 KBName:  IMG_3193.jpg
    But system not cooling well.
    Visit our website at www.airconcomfortcooling.com
  2. Likes Lahrs liked this post.
  3. #2
    Jul 2019
    Oklahoma home its in the name
    Was the compressor still alive?
    Sent from the Okie state usin Tapatalk
  4. #3
    Apr 2003
    Maple Grove, MN
    HOLY F! Is this real? Are you just messin with us? Please tell us more of the details.
    If at First You Don't Succeed, Skydiving Is Not for You.
  5. Likes dieseldude liked this post.
  6. #4
    May 2018
    FLORIDA
    yes its real
    a txv bulb on liquid line
  7. #5
    Apr 2020
    va
    critical charge system.......
  8. #6
    Mar 2016
    NY
    Quote Originally Posted by AIRCON8 View Post
    Well yeah, that’s the problem plain as day, the bulb isn’t insulated!
    “Happiness can be found, even in the darkest of times, if one only remembers to turn on the light.”
    "Ha! Memory is RAM!"
  9. #7
    Mar 2009
    Mount Holly, NC
    I wanna know how ANY corrosion got on the bulb...
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Click below to BECOME a pro member
    https://hvac-talk.com/vbb/forumdispl...ip-Information
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
  10. #8
    May 2018
    FLORIDA
    Quote Originally Posted by Bombboy90 View Post
    LOL i know right ?
  11. Likes dieseldude liked this post.
  12. #9
    Feb 2016
    N'awlins!
    Grainy photo, but is that suction line insulation fairly new?
  13. #10
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by davejohnsonnola View Post
    Ha! You might be on to something. It's a lot easier to insulate that suction line when that stupid thing-a-ma-jiggy isn't in the way. There... That's way better!
  14. Likes Bombboy90, Lahrs liked this post.
  15. #11
    May 2018
    FLORIDA
    its look like fair new, but the txv bulb is on the liquid line
  16. #12
    Feb 2016
    N'awlins!
    Corrosion on the bulb has me thinking it was installed correctly BEFORE the insulation was replaced.
  17. Likes 2sac liked this post.
  18. #13
    May 2018
    FLORIDA
    yeah i guess so
  19. #14
    Jul 2019
    Maybe they did that to try to get a txv that was running out of bulb charge to open enough.
  20. Likes Poodle Head Mikey liked this post.
  21. #15
    Sep 2012
    Quote Originally Posted by R600a View Post
    We used to have a unit at work that the bulb was pulled out of the cabinet for that reason till we could get a replacement for that reason ..... weirdly it took a couple years till it was replaced. When it was finally pulled the strainer was mostly plugged.
  22. #16
    Phoenix,AZ
    Must be the same guy!
  23. Likes vstech, sammyray liked this post.
  24. #17
    May 2018
    FLORIDA
    Quote Originally Posted by KB Cool View Post
    lol probably
  25. #18
    Jul 2003
    I had one were the bulb was in the coil cabinet in the supply air stream. Rhe owner saud they did alot of commercial refrigeration????? and not know how to hook up an expansion valve?
  26. #19
    Athens, Ohio
    Plenty of thermal conductivity with a cable tie, too!
    Site member map HERE!
  27. #20
    Jun 2006
    Victoria, Texas
    Give them some credit for attaching the bulb.
  28. Likes BALloyd liked this post.
