OK
Give us some info on what device type and browser you are using. Will see if we can duplicate it. A screen shot goes a long way too.
Today I have been having an issue with the "reply to post" button at the bottom right of the post, where it copies the post into your post.
When I click on it the cursor spins like it is doing something but nothing changes and the post box with the quoted post never appears.
OK
Dad, this is on my desktop, windows 10, Google chrome.
The pointer doesn't show up in the screen shot and it was spinning the whole time I was creating this post.
Hope this helps.
Test using Desktop 10 and Chrome
No spinning wheel, pointer works fine
Test
The problem I am having is with the "reply with quote". The reply box never shows up. When I click on the "reply with quote" button there is a circle of dots that shows up that is spinning and when I hover over that spot the pointer turns to a spinning blue circle. If I move the pointer away it will return to normal. When I did the screen shot both were on but it did not show up in the screenshot. It could be something on this end, it has been acting a little off today. Like when I started it, it acted like it had just had an update but it hadn't.
Take a moment to download and run this... I swear by it
So after you get your updates in give this a try... free to download and use.
https://www.softpedia.com/get/Antivi...Norascan.shtml
Thanks Dad.
I got a Windows update last night that was installed this AM. I installed and ran your Norascan. Then I cleared browser data, ran C-Cleaner, Avast, Malwarebytes, and SuperAntiSpyware. Your Norascan found something, C-Cleaner threw out the trash so to speak, and the other stuff all came back clean. Doing the Norascan and Browser didn't help completely, it would kinda work on one thread and only pull up multiple posts that I had done earlier in the week, but it is working now.
OK... so Ken, bottom line is that it is working now?
OK, good
In Norascan. Click the three boxes at the top right then scan full drive
It takes a while but it works well.
the same situation, don't know what to do
