+ Reply to Thread
Results 1 to 2 of 2
Thread: cleaning testo 550
    Mar 2018
    Richmond, VA
    cleaning testo 550
    Just had a crappy R22 system leave what looks to be an oily residue on the sight glass of my gauge set. I use the gauges for R22 and 410A so I'd rather not get any contamination in the next 410 unit I work on.
    What would you say is the best way to get this mess cleaned up?
    Jul 2020
    Lincoln Nebraska
    Isopropyl alcohol does a good job of dissolving most hydrocarbons. "Rubbing alcohol" is about 70% IPA with the balance of water. You could evacuate a container & suck IPA through your gauges, high/low lines each in a bottle of IPA, yellow to the vacuum tank. Then dry by blowing nitrogen (or CO2) thru and then finally drawing a vacuum on the set to make sure all the alcohol/water is gone.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
