+ Reply to Thread
Results 21 to 32 of 32
Thread: Boom !
  1. #21
  2. Likes ga-hvac-tech liked this post.
  3. #22
    Jun 2012
    Northern NV
    502 bad gateway message on initial link. Second page was letting me in..
    “A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.”
    ― Robert A. Heinlein
  5. #24
    Oct 2011
    Harrisburg, NC
    Test passed
    I can't fix it if it won't stay broke..
  6. #25
    S.E. Pa
    You musta' studied hard, Pop. You passed. Any chance pics and make/ model?
  7. #26
    Quote Originally Posted by hearthman View Post
    Not much to look at. Is a second FP in my breakfast nook. Logs aren't the issue... boom is in the flue or decorative cap.
    Was curious if anyone else has a booming flue. It booms several times a day sometimes a few times an hour.
  9. #28
    Jan 2015
    East Tenn
    U Mentioned a Chimney Box , NOT a Full Masonary Chimney . . Correct ?
    If that's So I have seen those Guys place a Lot of Straps - could be Pipe Moving inside ( Sliding ) Strap - over Locking Bulge or Screw Head ..
    Other Thing to do , Place Game Camera up in Attic near Sound - somewhere - Leave Set to ON for 6-12 Hours see _Log_ Time of Day & Temp it happens may Help in Pin Pointing ..
    Even Hang on Rope down into Flue to Record . . just some Idea's to Pin Point . .( Game Camera's Record all sounds ) Left On , but sometimes Sound will even Kick one on If Loud enough ..
    I've Heard Pop Sound - with a Wooden Pop type from Expansion & Contraction ~ When a Builder , Roofer has Missed on Truss to Nail Down Seam on Plywood or Sheeting ..
  10. #29
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    My guess would be the large rear steel wall of the fireplace box.
    Is the booming fireplace to the east or the west?
    Does the boom happen in the morning or the afternoon?
    PHM
    Quote Originally Posted by Dad View Post
    Need to run something by you guys.
    I have a couple of FP's in my home. Nothing fancy on this one, a firebox liner, gas logs to code and flue pipe with outside chimney box with vent cap and decorative surround.
    During the summer time while sitting in the breakfast area we keep hearing a "Boom". Nothing real loud it is subtle but similar to someone using explosives a few miles away. Am sure it has something to do with ambient heat expansion but what part is expanding and contracting?
    In other words... where do I start looking? Anyone else experience this that may know?
    Thx
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  12. #31
    Thanks but I think we figured it out... It is the flexing of the sheet metal from the black shroud.
    Oh; guess I am falling behind here. I seem confined to a chair right now so I am not working my usual seven days. <g>
    PHM
  13. #32
    PHM
    The boom happens only during the daylight hours in the heat of the day, never after dark.
    The chimney is on the south east corner. (My home faces due north) The fireplace is built in the corner of the breakfast nook with a 12' ceiling. Chimney exits the room to the outside after 8' of vent pipe.
    I am renovating the kitchen and doing some drywall work so I busted a hole in the wall above the firebox and took a look inside the wall. Everything is normal as can be. After inspecting inside the wall I can only gather it is the chimney shroud expanding and contracting.... thus the boom sound.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
