Results 1 to 7 of 7
Thread: shower leak on floor
    Sep 2009
    Any ideas what i can do to fix this without tearing out the shower?
    shower drain never backs up, but pipe below it does leak below shower floor and only when taking shower. See pics.
    The drain must be leaking. It gets wet inside that wall and with long showers, it leaks out onto the finished floor.
    Pic 2 is the lower part of that wall you see in the other pic (red box). With that blue plastic wall cover removed.
    wet with every shower where the yellow X is and then gets wet where the black X is with longer showers. shower drain is just a few inches higher and never backs up.
    This shower was installed over 10 years ago and this issue just started happening in the last 8 months. Started shortly after i had the outside sewer line replaced and tenant moved in at same time. maybe coincidence. Maybe previous tenants never took long showers.
    The other day we did run a snake down the shower drain at least 10 feet. that is well into the new sewer line that was replaced about 8 months ago. Its still getting wet as mentioned above after snakeing.
    Jun 2012
    Northern NV
    Crack in the fiberglass base perhaps?
    A dying culture invariably exhibits personal rudeness. Bad manners. Lack of consideration for others in minor matters. A loss of politeness, of gentle manners, is more significant than is a riot.
    ― Robert A. Heinlein
    Jun 2020
    Do you have a basement ? You should be able to access it from below.
    If not then heres what the issue is 99.99% of the time.
    Its probably the trim kit and not the drain. You should take some photos trim kit and how its mounted. Also, check that the trim kit is tight to the wall. Let us know nd snap some photos of the trim kit.
    Sep 2009
    after i remove the foam (and find and fix the leak), how about cutting some blocks to fit below the pan and using block caulking to hold in place?
    Sep 2009
    with grate removed
    Sep 2009
    Missing rubber gasket? What about using underwater rated caulking? Any other options that don't require removal of shower pan?
    Everything there is 10 years old.
    Sep 2009
    but it looks like the pipe is below the lower edge of the keyed drain assembly.
